Error Log Entries
Aug 25, 2013 4:57 PM
I have seen a slew of error log entries:
2013:08:02 18:18:29 : ..\..\sources\USheetSelection.cpp : 260 : REQUIRE failed
2013:08:02 18:19:23 : ..\..\sources\USheetSelection.cpp : 260 : REQUIRE failed
2013:08:06 18:57:32 : ..\..\sources\USheetSelection.cpp : 260 : REQUIRE failed
2013:08:10 04:15:44 : ..\..\sources\USheetSelection.cpp : 260 : REQUIRE failed
2013:08:10 21:21:10 : ..\..\sources\USheetSelection.cpp : 260 : REQUIRE failed
2013:08:13 18:13:22 : ..\..\sources\USheetSelection.cpp : 260 : REQUIRE failed
2013:08:13 20:04:52 : ..\..\sources\USheetSelection.cpp : 260 : REQUIRE failed
2013:08:14 17:31:18 : ..\..\sources\USheetSelection.cpp : 260 : REQUIRE failed
2013:08:14 20:08:09 : ..\..\sources\USheetSelection.cpp : 260 : REQUIRE failed
There are entries dating back to March 17, 2013
Before March 17 I was getting these errors
2012:05:31 06:06:13 : tracked key 00000000000000D0 of type struct _ADsc * __ptr64 not found : 1 : REQUIRE failed
2012:05:31 06:06:13 : e:\ps13\ps_13_win_x64_daily_retail\20120315.r.428\photoshop\main\phot oshop\interfaces\UTrackResourceImp.h : 149 : REQUIRE failed
2012:06:30 21:55:18 : tracked key 00000000000000D0 of type struct _ADsc * __ptr64 not found : 1 : REQUIRE failed
2012:06:30 21:55:18 : e:\ps13\ps_13_win_x64_daily_retail\20120315.r.428\photoshop\main\phot oshop\interfaces\UTrackResourceImp.h : 149 : REQUIRE failed
These errors have been logged since I installed CS6
Running CS6 Perpetual License Latest version on Windows 7 x64.  Vave no idea what these are refrerring to - anyone have a clue?
Not noticing any issues using CS6 or plug-ins -
Mike
    Aug 25, 2013 6:26 PM   in reply to MikeKPhoto
    The first is commonly related to problems with scripts, and the second can only be caused by scripts or automation plugins.
    Aug 25, 2013 8:54 PM   in reply to MikeKPhoto
    Could you be running some event scripts, or automation plugins (especially third party)?
    Oct 25, 2013 11:06 PM   in reply to MikeKPhoto
    I'm getting the USheetSelection.cpp : 260 : REQUIRE failed
    in the error log and I can't save anything
    I haven't changed anything
    but my list of recent files has disapearred
    CS6 extended photohop not working
  • Pierre Courtejoie
    Jan 11, 2006
    Oct 29, 2013 5:02 AM   in reply to MikeKPhoto
    Hello, are you sure that you are running the latest version? It should be 13.0.1.2 20130522
    Did you try to install it on your startup disk? Installing apps on another drive to recover them in case of a windows crash is more akin to superstition, given that the required registy entries would be lost.
