How to trim vectors to artboard dimensions
Aug 26, 2013 8:53 PM
Hello!
I have a multi layer doc. Many of the vectors peek out of the artboards dimensions. I need a clean trim to the exact dimensions. I was playing with the shapefinder but did not get the results I wanted.  What is the best way to trim off any vectors outside the artboard.
Maxi
    Aug 26, 2013 11:55 PM   in reply to Picturequest
    Nobody would usually bother, since when this is converted to a PDF or an image it becomes irrelevant and the artboard boundaries become your page bounds. Otherwise the simplest option would be to apply a clipping mask to everything short of pathfindering every object in the artwork... But again: Unless "clean" edges are required for some specific production process, one wouldn't bother.
    Mylenium
    Aug 27, 2013 8:57 AM   in reply to Picturequest
    This is not very precise, but might be what you need.
    here my objects come off the page. Use the eraser tool and hold Option/alt It will marquee over everything and delete a rectangle. Just make the rectangle go to the edge of your artboard.
    As I said, this isn't very presice, but it does exactly what you are asking for if I understand properly. A clipping mask that is the same size as the artboard will also work in most cases, but the vectors are still actually there. This kills them dead.
    Aug 27, 2013 11:29 AM   in reply to Picturequest
    > "I was playing with the shapefinder but did not get the results I wanted."
    What exactly did you do when playing with the Shape Builder tool? What was wrong about the results?
    Can you provide a sample .ai file?
    Which version of Illustrator are you using?
    Aug 27, 2013 2:15 PM   in reply to Picturequest
    Now we may be talking about different things.
    I thought you were using the Shape Builder tool. Probably you are using the Pathfinder panel instead, but I'm not sure. You call it the Shapefinder although a shapefinder does not exist in Illustrator, at least not something that is called like that.
    Telling which AI version you are using and providing a sample .ai file may still help to clarify.
    Aug 27, 2013 2:41 PM   in reply to Picturequest
    the video "shows" what elDudereno said and illustrated in post # 2
