• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Looping, Setting and Updating! Oh My.
Community Beginner ,
Aug 26, 2013 Aug 26, 2013
Hello all, I am very new to CF and our regular guy is on vaction so I could really use some help. I am getting geo location from Bing for multiple address that I have in a db. Then add the latitude and longitude to the latitude field and longitude field in the respective row I am able to run the function(s) indivulally but I need help looping through each row. Here is what I have. I hope this makes sense!
<!---query the db--->
<cfquery datasource="square" name="ListingShort">
            SELECT
                                        MLS_Id,List_Price,Public_Address,Street_Number,Street_Name,Unit_Number,City,Zip_Code,Subdivision_Name,Bedroom,Baths_Total,Full_Baths,Half_Baths,Square_Feet,Lot_Sqft,Garage_Capacity,Garage_Type,High_School,Junior_School,Property_Description,Listing_Office_Name,Listing_Office_Id,Listing_Agent_Name,Listing_Agent_Phone,Listing_Agent_Id,Short_Sale,Open_House_Flag,Last_Image_Update,Price_Change_Date,Image_Count,Latitude,Longitude
            FROM GLVAR_daily_bulk
                      WHERE MLS_Id=1375233
</cfquery>
<!---get the data back from Bing--->
<cfhttp url="http://dev.virtualearth.net/REST/v1/Locations/US/NV/#ListingShort.Zip_Code#/#ListingShort.City#/#Lis..." timeout = "2" method="GET">
<cfset xbinglocation = xmlparse(cfhttp.filecontent)>
<cfset lat=xbinglocation.Response.ResourceSets.ResourceSet.Resources.Location.Point.Latitude.XmlText>
<cfset long=xbinglocation.Response.ResourceSets.ResourceSet.Resources.Location.Point.Longitude.XmlText>
<!---update the latitude and longitude fields--->
<cfquery datasource="square" name="addGeo">
                              UPDATE glvar_daily_bulk
                              SET Latitude = #lat#,
               Longitude = #long#
</cfquery>
Views
800
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Beginner , Aug 27, 2013 Aug 27, 2013
Yo Thanks. Worked perfect. Im sure that was easy for you but you saved me countless google searches! I owe you one.
Votes
Translate
Translate
Engaged ,
Do you need to loop over all the rows, or just some of them?  I'm assuming the former.  In which case simply modify the first query to get all the records, then move the rest of the code into a loop over the query.
    SELECT MLS_Id,Street_Number,Street_Name,City
</cfquery>
<cfloop query="ListingShort">
        Longitude = #long#
        WHERE MLS_Id = #ListingShort.MLS_Id#
    </cfquery>
</cfloop>
Votes
Translate
Translate
Report
Report
Votes
Translate
Translate
Report
Report
Engaged ,
No problem.  Also it's a good idea to use <cfqueryparam> in all your queries when passing in values from elsewhere.  Basically it helps performance and reduces chances of SQL injection.  e.g.
        SET Latitude =<cfqueryparam value="#lat#" cfsqltype="cf_sql_float">,
        Longitude = <cfqueryparam value="#long#" cfsqltype="cf_sql_float">
        WHERE MLS_Id = <cfqueryparam value="#ListingShort.MLS_Id#" cfsqltype="cf_sql_integer">
    </cfquery>
Votes
Translate
Translate
Report
Report
Cool, thanks again. I hate to keep asking but is there a simple cfcatch or cftry that will skip the row if there is incorrect data that throws an error? Example in one row the city was set to "other" and Bing didn't like it. Could it be ignored and have the loop continue?
Votes
Translate
Translate
Report
Report
Engaged ,
It would depend a little bit on what Bing was doing.  e.g. if it returned a 404 or 500 error, you could watch for that using cfhttp.statusCode.
Or if it still returns a bunch of XML, you could check for that being in the correct format.
Or just wrap the whole thing in a try-catch (usually a good idea when calling an external website anyway).
This code combines the first and last ideas.
    <cftry>
        <cfif val(cfhttp.statusCode) EQ 200>  <!--- will turn "200 OK" into 200 --->
            </cfquery>
        </cfif>
        <cfcatch type="any">
            <cfoutput>Oops, an error on row ID = #ListingShort.MLS_Id#</cfoutput>  <cfdump var="#cfcatch#">
        </cfcatch>
    </cftry>
</cfloop>
Votes
Translate
Translate
Report
Report
LATEST
Seriously, thanks!
Votes
Translate
Translate
Report
Report
Resources
Documentation
