texber2012
Copy Keyframes from Spreadsheet AE CS5.5
Aug 27, 2013 1:07 PM
I've copied position keyframes from an AE composition to an Excel spreadsheet, did some editing and now I'm trying to copy/paste the new data back into the composition layer.  The "Paste" will not work.  I'm sure it must be something simple, but I cannot come up with it.  Any ideas? Thanks for your help.
    Aug 27, 2013 1:31 PM   in reply to texber2012
    Keyframes are just coma separated. You are going to be better off using a plain text editor. Excel is going to throw in a bunch of unnecessary code.
    Aug 27, 2013 9:17 PM   in reply to texber2012
    You should use a plain text editor.
    I forgot to mention that bezier information is not translated outside of AE. You'll end up with straight lines between points. If that's what you are seeing then that is normal. The copied keyframe data should look like the top of this exampls (invisibles showing) not like the bottom example (pasted from a word processor)
    Once again, don't expect curved paths or easing to be reproduced or edited. These values do not leave AE. I don't know where they are hidden, but when the clipboard data is sent to another app all interpolation between keyframes is lost.
    Aug 27, 2013 11:31 PM   in reply to texber2012
    Tried Word, that did not work either.
    But then again, Word is not a "text editor"... Use Textpad, BBEdit or even your system's own Editor application.
    Mylenium
