Building a simple TIMER
Aug 27, 2013 12:49 PM
In my word game, I have 30 Levels of letter tiles falling out of the sky.
I want to control these arrays(of movie clips) with a timer, so that I can start, pause and stop it at specific times.
I'm doing something wrong with the timer code. This is the error message I get:
TypeError: Error #1009: Cannot access a property or method of a null object reference.
    at WordArray/startTileTimer()
    at WordArray/activeLevelofTiles()
    at WordArray/tileGenerator()
    at WordArray/levelGenerator()
    at WordArray()
    at wordText/initWordText()
    at flash.display::DisplayObjectContainer/addChild()
    at BugGoopFSGame/startTimer()
How do I fix the timer? Should I have added it as an event listener somehow?
Relevant code below:
package
    import flash.display.*;
    import flash.text.TextField;
    import flash.events.Event;
    import flash.utils.Timer;
    import flash.events.*;
    import flash.events.MouseEvent;
    import flash.media.Sound;
    import flash.media.SoundChannel;
    public  dynamic class WordArray extends MovieClip
               public var wordtext:wordText =  new wordText;
                var activeWordArray:Array;
                var activeLevelofTenWordsArray:Array;
                var activeLevelofTilesArray:Array;
                public var letterArray:LetterArray;
                public var tileTimer:Timer;
        //Movie clips of letter tiles to be used
        public var a:A = new A();
        public var f:F =  //...etc
        private var wordArray:WordArray;
        private var letterTiles:Array = [a,f,g,h,i,...etc];
                              private var  lettersL01:Array = [a,a,f,f,f,g,g,h,h,i,i,n,n,n,o,o,o,o,s,s,t,t,t];
                              private var  lettersL02:Array = [th,th,  //...etc
                            public var letterLevels:Array = [lettersL01,lettersL02,lettersL03,...etc];
public var  wordsL1W1:Array = ["a"];
public var  wordsL1W2:Array = ["h","a","s"];
//...etc
public var  wordsL01:Array = [wordsL1W1,wordsL1W2,wordsL1W3,wordsL1W4,wordsL1W5,wordsL1W6,wordsL1W 7,wordsL1W8,wordsL1W9,wordsL1W10];
public var  wordsL02:Array = [wordsL2W1,  //...etc.
public var wordLevels:Array = [wordsL01,wordsL02,wordsL03,...etc]
                private var tf:TextField;
                // ***constructor code
                public function WordArray(_tf:TextField)
                   tf = _tf;
                    levelGenerator();
                    var tileTimer = new Timer(500,384);
                function levelGenerator():void
                   //**To get next level of 10 words
                    if(wordLevels.length>0)
                        activeLevelofTenWords();
                        tileGenerator();
                    else
                    //Game is complete
                function activeLevelofTenWords():void
                    //**To get next word
                    activeLevelofTenWordsArray = wordLevels.shift();
                    nextWordF();
                function tileGenerator():void
                    if(letterLevels.length>0)
                        activeLevelofTiles();
                    else
                    //Game is complete
                    function activeLevelofTiles():void
                        activeLevelofTilesArray = letterLevels.shift();
                        shuffleTiles(activeLevelofTilesArray);
                        trace(activeLevelofTilesArray);
                        startTileTimer();
                    function shuffleTiles(a:Array)
                        var p:int;
                                var t:*;
                                var ivar:int;
                                for (ivar = a.length-1; ivar>=0; ivar--)
                                    p=Math.floor((ivar+1)*Math.random());
                                    t = a[ivar];
                                    a[ivar] = a[p];
                                    a[p] = t;
                    function startTileTimer():void
                            tileTimer.start();
                            //Place the tiles to run
                            /*activeLevelofTilesArray.x = 399;
                            activeLevelofTilesArray.y= 30;
                            addChild(activeLevelofTilesArray);*/
                            trace("Letters should run");
               //rest of code not applicable
    Aug 27, 2013 1:41 PM   in reply to Charine -FB buggoop
    Declare the timer outside of any function, otherwise, by declaring it inside the WordArray function as you do its scope is limited to within that function - meaning it cannot be accessed outside the function.
    Aug 27, 2013 1:44 PM   in reply to Charine -FB buggoop
    You created that Timer in a function which means as soon as you leave the function it no longer exists because it's not class-level. Make it class-level like some of your other vars:
    private var myTimer:Timer;
    Then yes, you attach a TimerEvent listener to it and specify a function.
    myTimer.addEventListener(TimerEvent.TIMER, _handleTimer);
    function _handleTimer(e:TimerEvent):void
         // do what you want
