Insert Image Dialog Missing Insert URL
Aug 27, 2013 1:27 PM
I frequently prepare html for emailings and use an image link to an image already online.  The CS6 Insert Image Dialog box had a place at the bottom to enter the URL.  That seems to be gone.
Is there a way to turn it back on?
Seems that a lot of the good stuff the Jeremy Allaire put in there is getting stripped out.
There was a much more functional dialog box in CS6, the one in CC just grabs the built in Windows crap that is available to anything else.
Before:
After:
Please tell me there is a way to turn this back on??
Kirk
    Aug 27, 2013 1:51 PM   in reply to kirkdickinson
    Hi Kirk,
    You could type in your image url in the File Name text field and hit OK button. It would insert the remote image with src being the url. Please try it out and let us know if it works for you
    Regards,
    Janaki L
    Aug 28, 2013 5:22 AM   in reply to kirkdickinson
    Hi kirkdickinson,
    I tried this scenario both on 13(MAC) and 13.1 (WIN) using folllowing URL : https://www.google.co.in/intl/en_ALL/images/logos/images_logo_lg.gif
    I was not able to reproduced this issue.
    Basically 2 fields mentioned before have been merged into one to handle both HTTP links as well as regular file links.
    Also share your URL, let me check if its specific to that.
    Aug 28, 2013 5:27 AM   in reply to kirkdickinson
    To add to that it does takes a sec or 2 when URL is passed in File name field but Insertion process is successful.
    PS: I also checked on 13.0 on WIN and found the above stated behavior.
  • mattdwm
    Sep 6, 2010
    Sep 2, 2013 5:04 PM   in reply to kirkdickinson
    Doesn't work for me either (Mac 13.1). I can paste in the remote URL, but the open button stays disabled. The only option is to cancel and type it in manually.
    Sep 2, 2013 5:16 PM   in reply to mattdwm
    Can you try posting the link in the browser's address bar to see if the browser can retrieve the image.  In Expression Web 4 there is no specific url box and it too uses the file location space to insert the image.  I don't use DW CC ( only DW CS 6) so I can't check it out to see if it is working or not.  You could post a link here for people to test it for you.
  • mattdwm
    Sep 6, 2010
    Sep 2, 2013 5:28 PM   in reply to mytaxsite.co.uk
