Help understanding the options for Importing (.ia,pdf, etc)
Aug 27, 2013 2:20 PM
(CS6, CC)
In this case I am opening a .ia file, but same thing for a PDF. I get to the IMPORT dialog box, and there is a drop down menu CROP TO:
These are the options
Bounding
Media
Crop
Bleed
Trim
Art
In my case I wanted just the image withing the illustrator artboard. I do understand trim and bleed, but I'm not sure what is the difference between Bounding, Media, Art and Crop.
In my test they seemed to be the same?
Just trying to understand the differences.
Maxi
    Aug 27, 2013 2:35 PM   in reply to Picturequest
    these options.  Try crop if you want to crop to artboard.
    Adobe PDF placement options
    When you place an Adobe PDF file, you specify which page you want to import. You also choose how to crop the artwork by selecting a Crop To option:
    Bounding Box
    Places the PDF page’s bounding box, or the minimum area that encloses the objects on the page, including page marks.
    Art
    Places the PDF only in the area defined by a rectangle that the author created as placeable artwork (for example, clip art).
    Crop
    Places the PDF only in the area that is displayed or printed by Adobe Acrobat.
    Trim
    Identifies the place where the final produced page will be physically cut in the production process, if trim marks are present.
    Bleed
    Places only the area that represents where all page content should be clipped, if a bleed area is present. This information is useful if the page is being output in a production environment. Note that the printed page may include page marks that fall outside the bleed area.
    Media
    Places the area that represents the physical paper size of the original PDF document (for example, the dimensions of an A4 sheet of paper), including page marks.
