Exif "subject distance", shows in Bridge 5, gone in Bridge 6
Aug 27, 2013 3:53 PM
Tags: #problem #bridge #6
Just made the switch from CS5 to CS6.  The Camera Data (Exif) panel in Bridge 5 gives me the Subject Distance value.  In Bridge 6 that field is not shown.  Under Preferences>Metadata, the Subject Distance field is check in both versions.  What has happened to this datum in Bridge 6?
    Aug 27, 2013 5:18 PM   in reply to blumesan
    The solution and discussion is in this thread.  http://forums.adobe.com/thread/1134084?tstart=0
  • Omke Oudeman
    Nov 27, 2004
    Aug 28, 2013 12:57 AM   in reply to blumesan
    So the question remains: why is this datum displayed in the Camera Data (Exif) Panel of Bridge 5 but not in Bridge 6?  And what can be done to correct this glitch?
    Just a wild guess but CS6 was rewritten to 64 bit, they sadly enough did not made use of the opportunity to also implement much wanted/wished improvements but just changed the existing code to make it ready for 64 bit.
    While next to none knowledge about programming I know this was a hell of a lot work to do so either the custom script does not respond on this change or something has gone wrong in the transition?
    Try drop a new thread on the Bridge Scripting forum with this question.
