Where can I find the downloaded lens profile file (lcp)
Aug 27, 2013 11:58 PM
Tags: #lens_profile_creator
I used Adobe lens profile creator to download a lens profile. I cannot find the file. It is not in the standard folder for lens profiles.
Where does lens profile creator downloads the lcp file? It says local disk?
    Aug 28, 2013 12:59 AM   in reply to WinniHeyland
    Try a search for .lcp
    Aug 28, 2013 1:03 AM   in reply to WinniHeyland
    If you provide some essential details such as Operating System and Lightroom version, someone will be able to provide details of the default location for user-created lens profiles.
    Aug 28, 2013 1:35 AM   in reply to WinniHeyland
    On Windows: C:\Users\{username}\AppData\Roaming\Adobe\CameraRaw\LensProfiles\1.0\ Downloaded
    Aug 28, 2013 5:46 AM   in reply to WinniHeyland
    OK, you should be able to see the profile here:
    Macintosh HD / Users / [your username] / Library / Application Support / Adobe / CameraRaw / LensProfiles /
    Aug 28, 2013 6:39 AM   in reply to WinniHeyland
    On Mac OS X downloaded lens profiles are stored in this folder :
    Users/[user name]/Library/Preferences/Adobe/LensCorrection/1.0/Settings
    If it's not there check  the 'Location' field in the Adobe Lens Profile Downloader app. It should show as 'Installed' and not 'Online.' Also keep in mind that there are separate raw and JPEG lens profiles. A raw lens profile will not be visible inside LR with a JPEG image and vice-versa.
    Aug 28, 2013 7:09 AM   in reply to WinniHeyland
    In which case I can't help....that's the location that the downloader is supposed to use (in sub-folder "/1.0/Downloaded").
    Try downloading again maybe?
    Aug 28, 2013 7:45 AM   in reply to WinniHeyland
    Are you applying the lens profile to raw images or JPEG images?. As explained a raw lens profile will NOT be visible inside LR with JPEG image files.
    If you are using raw images then you may have to "manually" select the lens profile from inside LR's Lens Corrections> Profile panel:
    1) Make: Set to camera type (Canon, Nikon, etc.)
    2) Model: Select the downloaded lens profile
    3) Profile: (May show additional lens profiles available.)
    4) Setup: Select 'Save New Lens Profile Defaults'
    Downloaded lens profiles use "cryptic" alphanumeric naming. This is the type of file you will see inside the download folder:
    Example: b44f334142db4ead925447f8b5957f3e.lcp
