Photoshop PDF "Failed to Import PDF" - settings guide for text layers?
Aug 28, 2013 2:39 AM
I have edited an image of a Map - it came as a GIF.
I had to open the GIF and delete the text and lines pointing to certain areas.
I added text as Text Layers in Photoshop and saved it is a PSD for safe keeping.
I have now saved it as
PDF with Layers
PDF Compatilblity 6.0
But the PDF won't import to InDesign - it just says "Failed to Import PDF".
What settings are necessary to generate a PDF that will insert to InDesign from Photoshop?
    Aug 28, 2013 3:03 AM   in reply to Eugene Tyson
    What Color space did you use? Do you use indicated RGB (as it is used in GIFs)?
    Aug 28, 2013 5:07 AM   in reply to Eugene Tyson
    Change the file extension to PDP and it will be recognized as a Photoshop
    PDF. Also, if you show options when placing it usually clears up the can't
    place error message.
