Cant open attached files Dreamweaver CC update August
Aug 28, 2013 4:14 AM
Tags: #file #dreamweaver #update #open #cc
I installed the brandnew DW CC update from today (August, 27th, 2013) and now I cannot open the connected files any more in this subtab which shows all related (attached files), for instance the css file. Opening a file by its own is working.
Its always prompting that the cetrain file is not in the local directory and if I want to get it. Trying this also throws an error message.
The css file is working properly, it is stored locally and I can open it on its own.
It seems to be a bug with the new update?
Regards, Dennis
    Aug 28, 2013 4:30 AM   in reply to graugans Design
    I tried the same at my side in the updated version and its working fine.
    Did you try resetting the preferences.
    Refer the below to do so:
    http://helpx.adobe.com/dreamweaver/kb/restore-preferences-dreamweaver- cs4-cs5.html
    -Harshit yadav
    Aug 28, 2013 5:16 AM   in reply to hyadav
    @graugans Designs:
    CAn you please share the following details with us
    1. Is DW And your html on the same parttion in your MAC
    2. What is the error mesage on getting the file?
    3. If you are using servers , make sure that all your links are fine and files are available in the server
    Aug 30, 2013 2:52 AM   in reply to graugans Design
    Hi, Can you join me over connect to quickly go through your points
    Connect details over mail
    Aug 30, 2013 9:31 AM   in reply to vharis
    @graugans-designs :
    Thank you for bringing this issue to our notice .
    We noticed that files from such sites are not being previewed in Google Chrome too . Similar to the ones at http://forums.adobe.com/thread/1150112?tstart=30 We are investigating this issue with respect to the new CEF itegration in DW and will keep you guys posted on the developments on this front.
    Sep 3, 2013 10:23 PM   in reply to vharis
    @graugans Designs : Can you please check out http://forums.adobe.com/docs/DOC-3771 and rule out if that is not the case
    Sep 12, 2013 8:25 AM   in reply to graugans Design
    Hi
    Since upgrading to Dreamweaver 13.1 on my mac I'm having a similar issue. Any of the defined sites that are on our local shared server will not allow me to view related files but ones on my hard drive are fine. If I hover over the related file the link looks fine but I receive the message '<filename> is not on the local disk'.
    I have no error message when I open Dreamweaver and I have reset Dreamweavers' preferences. I've also re-defined all my site to no avail. I don't have similarly named folders on either my local drive or the shared server.
    Hope someone can help
    Vanessa
    Sep 12, 2013 8:38 AM   in reply to vanessa8595
    Copying from the known issues doc http://helpx.stage.adobe.com/dreamweaver/kb/known-issues-dreamweaver-1 31.html
    • On Mac, if a folder in any volume has the same name as the volume:
      • You cannot open the related files of a Dreamweaver site.
      • The Welcome screen of Dreamweaver does not load.
    Change the folder name and retry.
    Sep 12, 2013 8:54 AM   in reply to vharis
    Thanks for the swift response
    I found 2 files hidden away with the same name
    All working fine now
    Sep 12, 2013 8:54 AM   in reply to vanessa8595
    Rename the folders in the share. Try accessing a completely different folder from the share and see if you can see the related files
    IF you do not get me , Lets say you have a share at Some server/users/username/  which you have as your site root  and find tthat you cannot open the related files , try accessing some server/public/some file. yoiu will see that the trelated files will open up fine .
