Alpha tween in main timeline not tweening
Aug 28, 2013 8:33 AM
Hey guys
I'm trying to do something relatively simple... in theory.
I have a movie clip on the main timeline that I want to alpha tween from 100% to 0% over 8 frames. Now if I use the AS Tween class, it does just that, no problems with that.
However, if I attempt to do the tween using the timeline, it doesn't tween at all, it doesn't even acknowledge the alpha property on the keyframe, it just stays at 100%.
I don't want to use AS tweening as it's for running on specific hardware that doesn't lend itself well to anything that runs using a timer.
What could the problem here be?
Cheers
  • kglad
    Jul 21, 2002
    Aug 28, 2013 8:41 AM   in reply to LordMysterious
    almost certainly user error is the problem. attach a screenshot of your timeline.
    also, i'm dubious that timeline tweening will run more efficiently than as tweening.  what makes you think that?
    Aug 28, 2013 10:46 AM   in reply to LordMysterious
    It's pretty straight forward... I attached what I am thinking you're trying to do. Is that right?
    https://www.dropbox.com/s/swy1qwbbr7awqs4/tween%20example1.fla
