LinZD83
Elements 11 - creating a greeting/announcement
Aug 28, 2013 12:21 PM
I purchased elements 11 last year to not only edit photo's but also to create my own greeting and announcement cards.
I'm having trouble figuring out how to create a greeting from scratch. It seems as if I can only use Adobe's templates.
Is there any way I can create my own?
If so, how?
THank you
  • 99jon
    Jan 6, 2010
    Aug 28, 2013 2:14 PM   in reply to LinZD83
    It is possible to make a collage manually and its quite easy.
    Click File >> Open and select all of your photos
    That will add them to the project bin
    Then select File >> New >> Blank File
    Select background color White (or whatever you prefer) and add your width and height for your final image (set resolution 72 for web usage or 240 to 300 for printing) then click OK
    In the project bin click your first photo and drag it up into the main window on top of your new background.
    Click on the move tool and click in the center of the photo and drag to arrange it where you want on the background - you can hold down the shift key to maintain original proportions whilst dragging the corner handles of the bounding box to get the size you want.
    Do the same with the next photo (drag it up into the main window) and use the move tool to position it. Then continue with each image.
    Finally Click Layer >>Flatten image and save as jpeg. (Save as PSD if you want to preserve the layers for editing again)
    N.B. as you add images they get dropped in the center. So you need to use the move tool to drag them apart. Click in the middle of one and move it around, and then the others until you get them positioned as you want.
    When you click again with the move tool a bounding box appears around the image and you can drag out the corner handles to re-size your photos. Hold down the shift key when dragging the corner handle and that will maintain the proportions of the original.
    Finally click Layer >>Flatten Image and save your collage - you may then want to use the crop tool to cut away any surplus white canvas, and then re-save.
    N.B You can also add text as well as photos and graphics.
