IAmVexed
All the media files in my catalog went missing
Aug 28, 2013 12:14 PM
After installing PE 11 I started adding media to a catalog. At some point, I removed my hot swap hard disk, and after reinserting it, none of the files in the catalog are available. Everything is missing. I assume the hot swap was the cause.
My strategy now would be to erase the existing catalog, which is useless, and build a new one. Can I simply remove the catalog?
Where is it? How is it named.
    Aug 28, 2013 12:21 PM   in reply to IAmVexed
    The easiest way to create a new catalog is to go to the Organizer's File menu and select Manage Catalogs. On this screen you'll be able to create and assign a new catalog.
    Meantime, if you are are on Windows computer, you may want to use the Manage/Disk Management tool to permanently assign a drive letter to your external hard drive. This will keep the Organizer from losing its connection to it if you disconnect the drive and then reconnect it later.
