I'm trying to use the ChartBoost ANE which can be downloaded here https://github.com/freshplanet/ANE-Chartboost
When I do an Ad-hoc release build It keeps crashing and giving me the error below when packaging for iOS. But if I do a debug build that's a "fast" or "standard" build it compiles fine, and I can even see the ads.
Why would it crash when doing a release build? Does this ANE need an update?
I'm using FB 4.7 and AIR 3.8. Specifically, Apache Flex 4.10 Air 3.8
If I remove this 1 line of the Chartboost ANE code "AirChartboost.getInstance().showInterstitial();", the release build compiles fine and I can put it on the test iOS device.
"Error occurred while packaging the application:
AOT Compilation has failed while optimizing function public::AdsHelper.showFullscreenAd
Exception in thread "main" java.lang.NullPointerException
at java.util.TreeMap.getEntry(TreeMap.java:324)
at java.util.TreeMap.containsKey(TreeMap.java:209)
at adobe.abc.GlobalOptimizer.sccp_eval(GlobalOptimizer.java:6150)
at adobe.abc.GlobalOptimizer.sccp_analyze(GlobalOptimizer.java:6019)
at adobe.abc.GlobalOptimizer.sccp(GlobalOptimizer.java:4733)
at adobe.abc.GlobalOptimizer.optimize(GlobalOptimizer.java:3615)
at adobe.abc.GlobalOptimizer.optimize(GlobalOptimizer.java:2309)
at adobe.abc.LLVMEmitter.optimizeABCs(LLVMEmitter.java:534)
at adobe.abc.LLVMEmitter.generateBitcode(LLVMEmitter.java:343)
at com.adobe.air.ipa.AOTCompiler.convertAbcToLlvmBitcodeImpl(AOTCompiler.java:611)
at com.adobe.air.ipa.BitcodeGenerator.main(BitcodeGenerator.java:104)
Compilation failed while executing : ADT"
