sandyb2010
NEF thumbnails showing as bright pink why?
Aug 29, 2013 1:51 AM
Tags: #adobe #raw #bridge #pink #nef #acr
My NEF thumbnails have just started showing as bright pink in Bridge. They are ok when  I open them in ACR. I am using cs6 and Mac 10.5.6
  • Omke Oudeman
    Nov 27, 2004
    Aug 29, 2013 2:08 AM   in reply to sandyb2010
    In Bridge go to menu bar and select: Adobe Bridge CS6 / Camera Raw Preferences
    If under default image settings a checkmark shows in front of Apply Auto tone adjustments deselect it and hit OK. (the thumbs should rebuild but otherwise use menu tools / cache/ purge cache for folder to get the original thumbnails back.
    If this does not work try to add a screenshot with the problem.
  • Omke Oudeman
    Nov 27, 2004
    Aug 30, 2013 2:13 AM   in reply to sandyb2010
    That is indeed weird, no experience with Nikon (use Canon ) but it is not the first time problems about interaction between both brands are reported.
    However if it worked before there might have been some setting in NX2 changed if your Bridge settings did not change. But using Bridge Photodownloader from card reader is a workflow I am using for a long time without problems other then not importing High speed series not imported in the correct order as they where shot (using sort by create date in Bridge usually corrects this)
    Aug 31, 2013 8:55 AM   in reply to sandyb2010
    There was problems with NX1 in past, but have not heard any of NX2, which was why it was revised.
    Aug 31, 2013 7:07 PM   in reply to sandyb2010
    You might want to check in edit/camera raw preferences.  If you have any of the default setting boxes checked that could foul you up.
