nakea
Reading web service results
Aug 29, 2013 6:44 PM
Tags: #flashbuilder4.7
I have a flex application that consumes a web service I wrote in .net.
I'm having a hard time figuring out how to read the results of a CallResponder in my AS block, where I want to have some logic that makes a decision base on the result.
Example:
I have a webservice call (wsdl) that returns a Boolean response to whether an account exists based on an email and password passed in the call.
If I add the service to the Data/Services section, then right-click to generate the servcie call using FlashBuilder's auto-generate feature, it creates CallResponder and the ResultHandler function.
In the ResultHandler, It creates a CallResponder.token.
I've tried to cast it as a Boolean and run it through an "if" statement, but it always comes up false.
I have the same problem just reading the result, which I understand is returned as an object wrapped around an ArrayCollection. How do I read the response of a webservice call that returns an  Array of string results.
I've found a number of examples to simply bind to visual controls, which is great, but how do I read individual results to run some logic?
Appreciate the help and sorry if this is such a basic request. I'm a newby to Flex/FlashBuilder.
    Aug 30, 2013 7:22 AM   in reply to nakea
    Have you looked here?
    http://livedocs.adobe.com/flex/3/html/help.html?content=data_access_6. html
    If nothing else, use the debugger in the result handler to examine what the result is.
    Aug 31, 2013 10:53 AM   in reply to nakea
    You can't handle the result of the HTTP call inside the click handler - it's asynchronous.
    In the example I provided the link for there's a result handler for the http call: onResult
    That's where you handle the result - not in the click handler.
    Aug 31, 2013 3:43 PM   in reply to nakea
    You DO NOT CALL the onResult function. It is called by the system when a result is received from the remote server.
    When you send the HTTP request to the remote server your code continues before the result is ready.
    You really need to spend some time understanding the differrence between synchronous and asynchronous events.
    Sep 4, 2013 10:53 PM   in reply to nakea
    try to use event.result.GetListResult.Notes[1].Note
    Sep 5, 2013 2:11 AM   in reply to nakea
    because the xml namspace
    you define  xmlns="http://Nakea.net/TPI"
    so we should access the node in this namespace
    the code:
    public function showResult(event:ResultEvent):void
        var resultXML:XML = event.result;
        var defaultNS:Namespace = resultXML.namespace();
        txtArea2.text = resultXML.defaultNS::GetListResult.defaultNS::Notes[1].defaultNS::Not e;
