AlertAccImpl.as error
Aug 29, 2013 11:21 PM
I've posted to the AIR forum but I'm beginning to think this is a Flex framework question. This sounds like the issue (https://issues.apache.org/jira/browse/FLEX-17097) but I've hit a deadend trying to debug this thing.
I'm working on an app and I'm pretty stuck as the only code that comes up is below. I am trapping the escape key to stop a process. There are no Alerts in the message chain and I'm not quite sure where to go with the information I'm given, which occurs when I press the escape key.
TypeError: Error #1009: Cannot access a property or method of a null object reference.
  at mx.accessibility::AlertAccImpl/eventHandler()[E:\dev\4.y\frameworks\p rojects\mx\src\mx\accessibility\AlertAccImpl.as:177]
  at flash.events::EventDispatcher/dispatchEventFunction()
  at flash.events::EventDispatcher/dispatchEvent()
  at mx.core::UIComponent/dispatchEvent()[E:\dev\4.y\frameworks\projects\f ramework\src\mx\core\UIComponent.as:13152]
  at mx.controls.alertClasses::AlertForm/removeAlert()[E:\dev\4.y\framewor ks\projects\mx\src\mx\controls\alertClasses\AlertForm.as:522]
  at mx.controls.alertClasses::AlertForm/keyDownHandler()[E:\dev\4.y\frame works\projects\mx\src\mx\controls\alertClasses\AlertForm.as:546]
The framework code that it errors out at is the following. It says that systemManager is null. How can one make system manager null?
AlertAccImpl.as:
override protected function eventHandler(event:Event):void
  // Let AccImpl class handle the events
  // that all accessible UIComponents understand.
  $eventHandler(event);
  const systemManager:ISystemManager = ISystemManager(master.parent);
  var titleBar:UIComponent;
  switch (event.type)
  case "close":
  titleBar = Alert(master).getTitleBar();
  Accessibility.sendEvent(titleBar,0,AccConst.EVENT_SYSTEM_DIALOGEND);
  Accessibility.sendEvent(titleBar,0,AccConst.EVENT_OBJECT_REORDER);
  Accessibility.sendEvent(titleBar,0,AccConst.EVENT_OBJECT_DESTROY);
  Accessibility.sendEvent(titleBar,0,AccConst.EVENT_OBJECT_LOCATIONCHAN GE);
  Accessibility.sendEvent(titleBar,0,AccConst.EVENT_OBJECT_PARENTCHANGE );
  Accessibility.sendEvent(titleBar,0,AccConst.EVENT_OBJECT_HIDE);
  Accessibility.sendEvent(titleBar,0,AccConst.EVENT_SYSTEM_FOREGROUND);
  if (systemManager.stage.focus)
  Accessibility.sendEvent(systemManager.stage.focus,0,AccConst.EVENT_OB JECT_FOCUS);
  break;
    Aug 31, 2013 9:18 PM   in reply to John Hall
    There's an Alert somewhere.  Could be in a library.  Put a breakpoint on the Alert.show() and see who calls it.
    SystemManager might be null when an object is removed from the display list.
    Apache Flex has made some attempts to fix a similar error, but I'm not sure if it will fix your situation.  If you can come up with a simple test case, post it.
