LittleNewsMan
Difference b/w eps/jpg/pdf
Aug 30, 2013 2:32 PM
Tags: #pdf #indesign #exporting #to #computer #jpg #.eps #rip #plate
I work for a newspaper and for several months we have had sporadic issues when it comes to making our plates for the press. By issues, I mean those including pages that suddenly print upside down with the text appearing backwards and other instances where the text and images on a page are partially cut off or jagged.
Today I pin pointed the issue, discovering it had to do with the way some of our advertisements are being made in house.
It appears that when our ad designers go to a third party image site (Creative Outlet, which we subscribe to), they are sometimes downloading entire ads (which include several .eps files) and then pulling one piece of artwork from the ad to use in an entirely different ad.
I was able to locate a particular piece of said artwork that was utilized in one of our ads this past week. It was a .eps. I, instead, re-saved it as a .jpg, then relinked the file in Indesign, where our in-house ad had been built. I then exported as a .pdf and then placed that .pdf in our newspaper layout and exported the entire document to .pdf.
When we went to "roam" the page/pdf, the page was fine, except this ad did not have this piece of artwork showing.
I then went back and instead of exporting the ad as a .pdf, I exported it to .jpg. I then brought it into our newspaper layout, and exported it to .pdf.
When we roamed this page, the page was fine AND the ad now showed up in its entirety.
So, my question or questions, is/are:
1. What are the differences between .eps and .jpg and why would their distinction have an effect on the RIP process or computer to plate process?
2. What are the differences between .pdf and .jpg and why would their distinction have an effect on the RIP process or computer to plate process?
At the end of this, what I really just want to understand is why did the process I eventually came to (saving .eps file/artwork as .jpg, then after placing it in my ad document, exporting said document as a .jpg) work?
    Aug 30, 2013 11:03 PM   in reply to LittleNewsMan
    I can give you my non-expert opinion, and I'm sure that if I get something wrong, someone will be along shortly to correct me.
    Jpeg (Joint Photographic Experts Group) is a file format that uses a grid of pixels to represent an image, so it's a bitmap format. There are several bitmap formats that make them more or less useful in different circumstances. Because the amount of detail in a bitmap image is dependent upon the number of pixels it has, bitmap images can have very large file sizes.
    One way to reduce the file size is through compression. Compression can be done by at least two methods: Lossy and Lossless. With lossless compression, contiguous ranges of same-colored pixels that may be described as white, white, white, white, white, black, black, white, black without compression can be described as 5-whites, 2-blacks, white, black with lossless compression. No data is lost, but the reading device needs to be able to read the compressed data and uncompress it.
    The other way is called Lossless, in which groups of similarly-colored pixels are changed to a different color in order to create contiguous areas of same-colored pixels. So, if 100 was black and 0 was white (and numbers in between being shades of gray), you might get something like 100, 0, 100, 48, 49, 47, 48, 49, 100, 0, which when compressed might change to 100, 0, 5-47s, 100, 0, and the detail of the different colors is discarded from the file and lost (therefore, "lossy).
    With Jpeg, there is also the matter of areas of high compression leaving visual artifacts, which can be seen in the cat image in the Wikipedia page on Jpegs that I linked to above. Many people feel that jpeg is useful for situations where you need smaller file sizes (like low-capacity cameras and slow-connection web viewing), but are not good for printing where file size may be less of a concern than image quality.
    Tiff is a bitmap format that offers lossless LZW compression as an option, and Jpeg offers lossy compression that can be set on a scale from 0 to 12. The lower the number, the more data is lost.
    EPS (Encapsulated PostScript) is PostScript code (PostScript was originally designed as a protocol for computers to talk to certain types of laser printers) that has been encapsulated with the addition of extra data in order to allow that code to be used as a graphic format. PostScript data can contain bitmap data as well as Vector data (describing shapes with points and connecting lines and curves rather than a grid of pixels). If an eps contains only bitmap data, there is little reason to save it as eps, because modern workflows don't benefit from anything that eps could add, and other formats are usually recommended instead. Even if you have vector and bitmap data in the same image, eps is considered an older format that is better to avoid. PDF Tiff and PSD (Photoshop Document) are formats that can contain vector data and bitmap data.
    So, if your team are using eps files of whole ads, how are they doing it? Are they placing the eps into an image frame and using the frame's edges to crop out the unwanted areas? Are they opening the eps in another program and either cropping or removing parts of the ad and then saving? And if the latter, what editing programs are they using and what file format(s) are they saving as? As far as the images shifting, there could be reasons why it's doing that, but I could only speculate without seeing your files and your workflow, which I can't really do over a forum.
  • Rob Day
    Oct 16, 2007
    Aug 31, 2013 5:49 AM   in reply to LittleNewsMan
    Where are you resaving the .eps from? Photoshop? Can you open it in Illustrator and save to PDF from there?
