WillyWanna2
Procedure Entry point HandleWindowFont
Aug 31, 2013 7:05 AM
Tags: #editor #elements_11
Getting this error message regarding procedure entry point....You can click through it and it will eventually open but it's annoying as heck to have to do this every time I want to use PE11. Any advise will be appreciated...
    Aug 31, 2013 8:00 AM   in reply to WillyWanna2
    What version of windows are you using?
    Do you have any third party plugins installed in pse 11?
    Did you move/copy any plugins into pse 11 from another version of photoshop elements?
    Did you point the Additional Plugins preference in pse 11 to a folder that has plugins you wanted to use?
    Sep 1, 2013 1:53 AM   in reply to WillyWanna2
    Could you post the contents of Help>System Info from within the photoshop elements 11 editor?
    That might help us see if there is a odd dll or plugin that might be causing that error.
    Another way is to unistall pse 11, then go and delete the folder Photoshop Elements 11
    in the program files and then reinstall pse 11.
    C:\Program Files (x86)\Adobe\Photoshop Elements 11 (64 bit windows 7)
    C:\Program Files\Adobe\Photoshop Elements 11 (32 bit windows 7)
    If you have any plugins you want to install, check with the maker for compatibility with pse 11
    and use the plugin installer to install the plugins.
    Sep 1, 2013 7:07 AM   in reply to WillyWanna2
    A couple of things i see:
    1. You should uncheck the additional pluhins folder under
         Edit>Preferences>Plug-Ins>Additional Plug-Ins Folder
    2. you seem to have a bunch of plugins in the pse 11 plugins folder
        C:\Program Files (x86)\Adobe\Photoshop Elements 11\Plug-Ins
    those aren't really needed since they are mostly repeats of the ones that pse 11 already has, so you should
    remove those as well.
    Hopefully those two things will take care of the error messages your getting in pse 11.
    Sep 1, 2013 10:11 AM   in reply to WillyWanna2
    Filter forge 3 should be compatible with pse 11.
    http://www.filterforge.com/download/hosts.html
    Did you try using the filter forge installer?
