After effects EXTREMELY LAGGY
Sep 1, 2013 7:13 PM
Hey guys, this is a huge problem I really hope you guys can fix. So I am on AE CS6 Version 11.0.2.11 and I am working on a project in a composition with some effects, but not NEARLY enough to cause this much of a problem. So, with these effects, every time I try move a keyframe, or adjust the CTI, or change a single value, After effects lags and freezes for like 1 minute and then continues on normally just to present me with the same issue. So basically every time I make edits in my composition after effects freezes up.
Now for the specs....
- MacBook Pro on OS X Lion 10.7.5
- 2.8 GHz Intel Core i7 Processor
- 16 GB 1333 MHz DDR3 RAM
- Intel HD Graphics 3000 512 MB
In the Media disc cache section of preferences, I have 500 GB alotted on an SSD 1TB external drive (Yes I have tried emptying disk cache)
Everything in the discussion has worked extremely well on my machine, and the problem came up just recently.
-OpenGL is disabled
These are all of the effects included (please note I have used all of the without problem):
-Twixtor
-3d camera tracker
-Trapcode Shine
I am also working with 29.97 Fps 1280 x 720 dimensions. The file is a .mp4 with a H.264 and AAC codec.
I really don't know what the problem is. If you are reading this PLEASE take a shot at fixing this. I will be happy to supply ANY more information you guys need so just ask! Thank you for your time.
    Sep 2, 2013 8:48 AM   in reply to OrangeJuicee
    I'd do two things: First, I'd transcode the mp4 footage to quicktimes in ProRes 422 (if you have it), PNG or Animation.  Then I'd do the Twixtor work & render it out.  After that, you should be good to go.
    You're asking AE to do A LOT of  computing by working with a highly7-compressed codec like h.264, PLUS frame rate conversion.
    It also wouldn't hurt to turn off multiprocessing temporarily if you're using it.
    Sep 3, 2013 6:51 AM   in reply to OrangeJuicee
    What happens if you transcode the footage into a production codec first and then use it, rather than using footage that uses an interframe compression codec?
    Sep 3, 2013 10:21 PM   in reply to OrangeJuicee
    You could use Premiere, but it would be quicker to use the Adobe Media Encoder. Simply load your file into the Adobe Media Encoder and pick a lossless codec for your output. Quicktime with the PNG codec is a popular one. Be prepared for a large file size though, as h.264 is highly compressed compared to lossless video.
