Error: Could not find compiled resource bundle 'logging' for locale 'fr_FR'
Sep 2, 2013 1:16 AM
Tags: #problem #air #flex-mobile #flash_builder #flex-4.6 #4.6
Hello
I'm developping a mobile application based on Flex  4.6 + Adobe AIR 3.5
There is no error when compiling, but when the application starts it crashes whith this error message:
Error: Could not find compiled resource bundle 'logging' for locale 'fr_FR'.
  at mx.resources::ResourceManagerImpl/installCompiledResourceBundle()[E:\ dev\4.y\frameworks\projects\framework\src\mx\resources\ResourceManager Impl.as:392]
  at mx.resources::ResourceManagerImpl/installCompiledResourceBundles()[E: \dev\4.y\frameworks\projects\framework\src\mx\resources\ResourceManage rImpl.as:306]
  at mx.resources::ResourceManagerImpl/processInfo()[E:\dev\4.y\frameworks \projects\framework\src\mx\resources\ResourceManagerImpl.as:450]
  at mx.resources::ResourceManagerImpl()[E:\dev\4.y\frameworks\projects\fr amework\src\mx\resources\ResourceManagerImpl.as:133]
  at mx.resources::ResourceManager$/getInstance()[E:\dev\4.y\frameworks\pr ojects\framework\src\mx\resources\ResourceManager.as:117]
  at mx.styles::StyleManagerImpl()[E:\dev\4.y\frameworks\projects\framewor k\src\mx\styles\StyleManagerImpl.as:380]
  at _ASMagnetoFute_iOS_FlexInit$/init()
  at mx.managers::SystemManager/http://www.adobe.com/2006/flex/mx/internal::kickOff()[E:\dev\4.y\frameworks\projects\framework\src\mx\managers\SystemMana ger.as:2815]
  at mx.managers::SystemManager/http://www.adobe.com/2006/flex/mx/internal::preloader_completeHandler()[E:\dev\4.y\frameworks\projects\framework\src\mx\managers\SystemMana ger.as:2723]
  at flash.events::EventDispatcher/dispatchEventFunction()
  at flash.events::EventDispatcher/dispatchEvent()
  at mx.preloaders::Preloader/timerHandler()[E:\dev\4.y\frameworks\project s\framework\src\mx\preloaders\Preloader.as:542]
  at flash.utils::Timer/_timerDispatch()
  at flash.utils::Timer/tick()
The application is in french, both for iOS and Android.
It is split in several libs, an application for iOS and another one for android.
I use the same SDK for another mobile application without any problem -but it does not use the mx.logging package.
I tried many things, like the solution described in http://forums.adobe.com/thread/758619, but it did not solve the problem. After listing the bundles used I added
-include-resource-bundles=MagnetoFute,collections,components,core,effe cts,fiber,layout,logging,messaging,rpc,serializer,skins,sparkEffects,s tyles,textLayout,utils,validators
to my compiler arguments.
Help would be greatly appreciated.
    Sep 2, 2013 9:54 PM   in reply to Pascal Le Merrer
    I don't know if Adobe has an fr_FR locale for the logging bundle.  You can try creating your own to see if that is the only one missing or if there is a whole resource swc missing.
