Someone helped me last time with my sounds. Now, when my player enters in a scene, a new sound starts (and the sound of the previous background stops).
But now I can't find a way to loop the sound in each background...I'm trying to use
public function playSound():void{
channel = music.play();
channel.soundTransform = transformer;
channel.addEventListener(Event.SOUND_COMPLETE, loopSound, false, 0, true);
private function loopSound(e:Event):void{
channel.removeEventListener(Event.SOUND_COMPLETE, loopSound);
playSound();
But it doesn't seem to work. In fact, I don't really know when should I call this function.
I've got a quite simple code :
public var currentSoundChannel:SoundChannel;
public function newBackground(thisBack:String):void
var room = back.currentBack;
if (currentSoundChannel != null)
currentSoundChannel.stop()
var nextSong:Sound;
switch (thisBack){
case "maisonExt":
nextSong = new exterieur ();
break;
case "garage":
nextSong = new mouche ();
break;
case "monde":
nextSong = new cartesnd();
break;
currentSoundChannel = nextSong.play();
So, where should I put my loopsound function ?
Thank you very much !
use:
public function Muzak(musicURL:String, musicVol:Number){ this.musicURL = musicURL; if(musicURL != ""){ music = new Sound(new URLRequest(musicURL)); transformer = new SoundTransform(musicVol, 0); playSound();
your sound's play() methods accept a loop paramenter:
channel = music.play(0,100); // 100 loops
And I should put "channel = music.play(0,100); // 100 loops" where exactly in order to have a loop sound in each background ?
replace:
with:
Nope, It's not working...I'm not sure that "var nextSong" is using the playSound function...
what code are you using to play your sound?
Normaly I use a class for the background music named "musique.as". Here's the code :
if(musicURL != ""){
playSound();
playSound();
public function changeVolume(newVol:Number):void{
if(musicURL != ""){
transformer.volume = newVol;
public function stopSound():void{
channel.stop();
But as I wanted to change the music in each background so I add in my Engine class :
public function newBackground(thisBack:String):void {
var nextSong:Sound;
nextSong = new "mysoundname"();
} currentSoundChannel = nextSong.play();
use:
public function Muzak(musicURL:String, musicVol:Number){ this.musicURL = musicURL; if(musicURL != ""){ music = new Sound(new URLRequest(musicURL)); transformer = new SoundTransform(musicVol, 0); playSound(); } } public function playSound():void{ channel = music.play(0,100); channel.soundTransform = transformer; // channel.addEventListener(Event.SOUND_COMPLETE, loopSound, false, 0, true); } private function loopSound(e:Event):void{ channel.removeEventListener(Event.SOUND_COMPLETE, loopSound); playSound(); } public function changeVolume(newVol:Number):void{ if(musicURL != ""){ transformer.volume = newVol; channel.soundTransform = transformer; } } public function stopSound():void{ channel.stop(); }
var nextSong:Sound;
} currentSoundChannel = nextSong.play(0,100);
PERFECT ! THANK YOU VERY MUCH !!!!
you're welcome.
