StageVideo usage from Flex window application(AIR dekstop)?
Sep 5, 2013 8:03 PM
Hello, everyone.
I am newbie to Flex and I'm found the flex which help me a lot.
Recently, I found a snippet of code from forum, which does what I want but only the output is not what I expected.
i wish to create a window application using flex project(stagevideo) which able to display video in adobe AIR.
the AS3 code with stagevideo class which i able to display using AS project but if i try to use the same code in flex project (not flex mobile project) i get not video output.
I guess there is not way to attach code to this post. It's a basic window application project using flex for desktop. I appreciate if any of you able to have a look at it.
thank you so much ^.^
(using adobe AIR 3.8.0.870)
(in src package>default package)
main.mxml
  <s:WindowedApplication xmlns:fx="http://ns.adobe.com/mxml/2009"
                                                     xmlns:mx="library://ns.adobe.com/flex/mx"
                                                     backgroundAlpha="0">
          <fx:Declarations>
                    <!-- Place non-visual elements (e.g., services, value objects) here -->
          </fx:Declarations>
</s:WindowedApplication>
stageTest.as
package
          import flash.display.Sprite;
          import flash.display.Stage;
          import flash.events.Event;
          import flash.events.NetStatusEvent;
          import flash.events.StageVideoAvailabilityEvent;
          import flash.events.StageVideoEvent;
          import flash.geom.Rectangle;
          import flash.media.StageVideo;
          import flash.media.StageVideoAvailability;
          import flash.media.Video;
          import flash.net.NetConnection;
          import flash.net.NetStream;
          [SWF (width="640", height="360")]
          public class stageTest extends Sprite
                    private var stageVideoAvail:Boolean;
                    private var sv:StageVideo;
                    private var rc:Rectangle;
                    private var supportStageVideo:Boolean;
                    private var ns:NetStream;
                    private var played:Boolean;
                    private var stageVideoInUse:Boolean;
                    private var classicVideoInUse:Boolean;
                    private var vid:Video;
                    public function stageTest()
                              stage.addEventListener(StageVideoAvailabilityEvent.STA GE_VIDEO_AVAILABILITY, onAvail);
                    private function onAvail(event:StageVideoAvailabilityEvent):void
                              stageVideoAvail=(event.availability == StageVideoAvailability.AVAILABLE);
                              initVideo();
                    private function initVideo():void
                              var nc:NetConnection = new NetConnection();
                              nc.connect(null);
                              var ns:NetStream = new NetStream(nc);
                              ns.client= this;
                              if(stageVideoAvail)
                                        sv:stage.stageVideos[0];
                                        sv.addEventListener(StageVideoEvent.RENDER_STATE, onRender);
                                        sv.attachNetStream(ns);
                              else
                                        var vid:Video = new Video(640,360);
                                        addChild(vid);
                                        vid.attachNetStream(ns);
                              ns.play("try1.mp4");
                    private function onRender(event:StageVideoEvent):void
                              sv.viewPort = new Rectangle(0,0,640,360);
                    public function onMetaData(event:Object):void
                    public function onXMPData(event:Object):void
                    private  function onStageVideoState(event:StageVideoAvailabilityEvent):void
                              supportStageVideo = (event.availability  == StageVideoAvailability.AVAILABLE);
                              trace("supportStageVideo-="+supportStageVideo);
                              stage.removeEventListener(StageVideoAvailabilityEvent. STAGE_VIDEO_AVAILABILITY,  onStageVideoState);
                    private function stageVideoStateChange(event:StageVideoEvent):void
                              var status:String = event.status;
                              resize();
                    private function resize ():void
                              rc = computeVideoRect(sv.videoWidth, sv.videoHeight);
                              sv.viewPort = rc;
                    private function computeVideoRect(s:Number,b:Number):Rectangle
                              return new Rectangle(0,0,s,b);
    Sep 6, 2013 8:56 AM   in reply to LynSing717
    Search the internet for how other folks have done it.  I think they set backgroundAlpha=0 on the Application tag.  Do you hear the audio?  I think Flex defaults to drawing a background that covers the video.
    Sep 8, 2013 9:01 PM   in reply to LynSing717
    So you see the video but there is no audio?  Maybe try another video.
    -Alex
    Sep 8, 2013 9:40 PM   in reply to LynSing717
    See this thread: http://forums.adobe.com/message/4554510
    Also check the documentation about using renderMode or wmode correctly.
    -Alex
    Sep 11, 2013 8:29 AM   in reply to LynSing717
    You may find that a custom skinClass works, especially if a backgroundImage is being used.  But you should be hearing audio and just not seeing video if that is the problem.
    If you don't even get audio, you may want to try an ActionScript-only Project that uses StageVideo and/or a regular Flex project that uses the Spark or mx Video controls to make sure Flash can find and display the video.  There might be a security issue or a bad URL preventing the video from playing anything at all.
    There are some differences between mobile and non-mobile AIR application support, but I don't know if video is one of the differences.
    -Alex
    Sep 12, 2013 9:32 PM   in reply to LynSing717
    I've never really worked with video.  Try an ActionScript-only project.  Make sure the renderMode/wmode is set correctly.  Here's one article: http://www.adobe.com/devnet/flashplayer/articles/stage_video.html
    -Alex
