drelidan
How do I work around PIGetStr placing an invalid character in character buffer?
Sep 6, 2013 1:19 PM
In an Export plug-in, I need to read in the destination file path from scripting parameters.  Often, the character at exportPath[0] is junk and not an actual part of the path (hence the check).  Recently, this junk has actually been alphanumeric characters.  I can write a more accurate platform-dependent workaround, but would prefer an actual solution.  As a note, this happens whenever I use PIGetStr, not just in the case of reading filepaths.
Is there a standard way to handle this behavior?
Example:
case keyFilePath:
                    Str255 exportPath;
                    PIGetStr(token, &exportPath);
                    byte offset = 0;
                    if(!isalpha(exportPath[0]))
                                   offset = 1;
                    strcpy_s((char*)gDestination, 256 - offset, (char*)exportPath + offset);
                    DescParams->playInfo = 0; //Don't pop dialog.
                    break;
Result in exportPath:  Ec:\temp\assets\textures\brick_stacked_tile_01_SpecColor_gradients.dd s
Expected:  c:\temp\assets\textures\brick_stacked_tile_01_SpecColor_gradients.dds
    Sep 6, 2013 2:07 PM   in reply to drelidan
    From PITypes.h:
    typedef unsigned char Str255[256];  /*  first byte length of string. The string is zero terminated. */
    It's pure legacy - this is how strings in ol' good Pascal used to be organized
