LR won't import RAW files from D800
Sep 6, 2013 2:19 PM
I'm not able to import RAW files shot on a D800 into LR3. I was told about a patch I needed...can someone please advise?
    Sep 6, 2013 2:44 PM   in reply to CarlyK73
    There is no patch that will ever make Lightroom 3 read NEF files from that camera. The camera was introduced after support for Lightroom 3 ended. But you can use the newest DNG converter to create digital negative (DNG) copies of your raw images, and they can be opened using Lightroom 3. But I can tell you that you would be much happier if you had Lightroom 5. It has direct support for your camera, and a much improved process version.
    Sep 7, 2013 6:05 AM   in reply to CarlyK73
    Carly, why not get the (free to use until it expires) release 5.2 RC?
    Sep 7, 2013 6:28 AM   in reply to Keith_Reeder
    Careful - the Adobe text says LR 5.2 RC expires at the end of September, so you'll need another version then.  Also, LR5.x catalogues can't be read by LR3.x (or LR4.x, or anything earlier), so there's no going back.
    Sep 7, 2013 7:36 AM   in reply to CSS Simon
    Let's be clear about that. Lightroom 5.2 RC will upgrade the older catalog, but it does that by creating a copy of the original. The older version of Lightroom, and the catalog which it uses, remain intact and completely usable. The only thing that would become confusing in this situation would be trying to use both versions. You would most likely see different interpretations.
    Sep 7, 2013 11:59 AM   in reply to CSS Simon
    Fair point SImon - but I get the sense that the OP's prime interest is in getting the second shooter's files converted rather than converted and catalogued, and 5.2 RC is a viable stop-gap for that purpose.
