hhfrancois
java.lang.ClassNotFoundException: flex2.compiler.i18n.PropertyTranslationFormat
Sep 9, 2013 2:48 PM
Tags: #java #flex #compile
Hi, I try to compile generated library with java process.
So I use the library flex-compiler-oem.jar
And I do something like that :
lib = new Library();
lib.addComponent(new File(sourcesDir, "ClassAS.as"));
lib.setOutput(new File(swcDir, libraryName));
lib.build(true);
but after the message : Loading configuration file E:\flexsdks\3.5.0\frameworks\flex-config.xml
I have a beautiful stacktrace
Error: java.lang.ClassNotFoundException: flex2.compiler.i18n.PropertyTranslationFormat
          at java.net.URLClassLoader$1.run(URLClassLoader.java:366)
          at java.net.URLClassLoader$1.run(URLClassLoader.java:355)
          at java.security.AccessController.doPrivileged(Native Method)
          at java.net.URLClassLoader.findClass(URLClassLoader.java:354)
          at org.apache.tools.ant.module.bridge.AntBridge$MainClassLoader.findClass(AntBridge.java:647)
          at java.lang.ClassLoader.loadClass(ClassLoader.java:424)
          at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
          at java.lang.Class.forName0(Native Method)
          at java.lang.Class.forName(Class.java:270)
          at flex2.compiler.i18n.I18nUtils.getTranslationFormat(I18nUtils.java:395)
          at flex2.compiler.i18n.Compiler.<init>(Compiler.java:105)
          at flex2.tools.API.getCompilers(API.java:261)
          at flex2.tools.oem.Library.recompile(Library.java:739)
          at flex2.tools.oem.Library.compile(Library.java:1205)
          at flex2.tools.oem.Library.build(Library.java:611)
The class PropertyTranslationFormat is in classpath in fact, I dont understand, and I found nothing from google
Someone meet this issues ?
    Sep 9, 2013 3:14 PM   in reply to hhfrancois
    Try using compc.
    Sep 9, 2013 3:21 PM   in reply to hhfrancois
    If you use -link–report to generate a link report you can see for the test case that worked where it found the logging resources.  Then check your project settings to make sure those resources are available to your project.
