DigiWannaBe
Grey Spots on Background After VideoMerge
Sep 10, 2013 9:49 AM
Tags: #11 #problems #videomerge #primiere_elements
I use a green screen, and after applying videomerge to remove the background I often get "grey areas" that persist after applying a new background.  They show up in random locations on the removed layer.
Any ideas that may cause this?  I've tried applying "green screen key" and "chroma key" instead of videomerge, but videomerge doesn't affect the front layer images.
Could this be from lighting?  I've yet to be able to solve this as I've tried, coloring, saturation, etc.  HELP!
    Sep 10, 2013 10:11 AM   in reply to DigiWannaBe
    DigiWannaBe
    What version of Premiere Elements are you using and on what computer operating system is it running?
    When you are using ChromaKey, are you editing the effect with the adjusts in the ChromaKey panel, including Sensitivity?
    Have you sampled various spots in the image as the target of the wanted transparency?
    From the screenshot colors that I picking up on, it looks like there are shades of blue as well as green in that image which is
    being grabbed from green screening.
    ATR
    Sep 10, 2013 10:48 AM   in reply to DigiWannaBe
    DigiWannaBe
    I will be back in a moment. I am preparing some screenshots as a demo for your possible use of ChromaKey for your green screening.
    But, I did want to acknowledge a goof in my prior post. I wrote Sensitivity where it should have been Similarity. Sorry about that. Everything else in that post is as written.
    More soon.
    ATR
    Sep 10, 2013 11:02 AM   in reply to DigiWannaBe
    DigiWannaBe
    Given you have an image, such as the following and you import that into Premiere Elements 11 on Windows 7 64 bit and obtain your image on a transparent background.
    Highlight the clip, and then fx Effects tab/Keying/ChromaKey at the bottom of the Expert workspace, followed by
    Applied Effects/Applied Effects Palette/ChromaKey Panel expanded. It should look something like the following in principle.
    2.JPG.
    Then, in the ChromaKey options, click on the eyedropper and then on the green on screen (the green
    that you want to replace with transparency). When you do, you should see something like the following in
    principle. Remember, Premiere Elements uses black to represent transparency.
    You now have your transparency areas; however probably there will probably be edges of
    the image that need fine tuning. For that, move the Similarlty slider to the right slowly to the
    point where you get the cleanest edges around the image.
    Does any of that help. Or, have you been there and done that already. Complications
    set in when the image itself has colors similar to the color that you are trying to convert
    into transparency.
    ChromaKey should be able to handle a green or blue screening. But, as you know, the preparation
    of the green or blue screening before it gets into Premiere Elements is critical to success.
    We will be watching for your results.
    Thanks.
    ATR
    Sep 10, 2013 11:03 AM   in reply to DigiWannaBe
    Greg Galat
    Please remove your telephone number to avoid potential nuisances to that number.
    I am not a moderator, so I cannot take care of that for you.
    Thanks.
    ATR
    Sep 10, 2013 12:18 PM   in reply to DigiWannaBe
    Greg
    There are all sorts of variations on this.
    So, let us see how the prior suggestion fares and then we can decide what next.
    Thanks.
    ATR
    Sep 11, 2013 6:05 PM   in reply to DigiWannaBe
    Greg,
    Thanks for the great news of your success with your ChromaKeying. Good job.
    Your follow up was much appreciated so that we know that you are moving forward in your Premiere Elements projects.
    Continuing success.
    ATR
