I think a couple people asked about this problem but none of them seemed to get an answer so I am re-posting.
This is how blur filter and mask work in code
var blur:BlurFilter = new BlurFilter();
blur.blurX = 10;
blur.blurY = 10;
var mask:Bitmap = new Bitmap(...)
var shape:Shape = new Shape();
shape.graphics.beginFill(color, alpha);
shape.graphics.moveTo(100, 100);
shape.graphics.lineTo(...);
shape.graphics.endFill();
shape.filters = [blur]
shape.mask = mask;
bitmap.bitmapData.draw(shape);
But result is not what I want. Please see the below image:
Making another bitmap and copy pixels using the mask works but it makes whole applcation very slow.
How can I mask blur filter using a single draw?
The difference between the code I posted and what you have there is that you are applying the mask and the blur to the shape, whereas I applied the blur to the shape and the mask to a container the shape is inside. This is because for a given object the filters apply AFTER any masking, but you want the reverse. The only way to control the order that I know if is to create more layers.
In other words, change the last code you posted like this:
1. Create a container for the shape:
...var container:Sprit
Have you tried putting the shape inside a movieclip and apply the mask to the movieclip instead of the shape?
Thanks for asking. As far as I know, the "graphic" in shape behaviours exactly same with one in sprite or movieclip
Can you post the complete code with the mask and shape defined?
Here is my code:
public static function drawPolygon(bitmap:Bitmap, points:Array, color:uint, alpha:Number=1.0, filters:Array=null, mask:Bitmap=null):void
if(points == null || points.length < 3) {
return;
shape.graphics.moveTo(points[0].x, points[0].y);
var i:int;
for(i=1;i<points.length;i++) {
shape.graphics.lineTo(points.x, points.y);
if(filters != null) {
shape.filters = filters;
if(mask != null) {
shape.cacheAsBitmap = true;
mask.cacheAsBitmap = true;
shape.mask = mask;
//create blur filter
blur.blurX = 10;
blur.blurY = 10;
//create mask
var mask:Bitmap = new Bitmap(new BitmapData(bitmap.width, bitmap.height));
Tools.fillWithOneColor(mask, 0x000000);
Tools.drawPolygon(mask, maskPoints, 0xffffff);
//draw blured and masked polygon
Tools.drawPolygon(bitmap, points, _color, _alpha/2, [blur], mask);
Please let me know if there is anything I sould change..
It`s not advisable to name your instances with reserved keywords, properties etc.
try
_shape.filters = [blur];
_shape.cacheAsBitmap = true;
_mask.cacheAsBitmap = true;
shape.mask = _mask;
Thanks for replying. but that does not work in my side unfortunately. Please take a look at my code
filters in Flash are somwhat unreliable when combined with masking.
Try to use a non native famework like greensock ( http://www.greensock.com/tweenmax/ )
and rewrite your blurfilter like this:
import com.greensock.*;
import com.greensock.easing.*;
TweenMax.to(shape, 0, {blurFilter:{blurX:10, blurY:10}});
Thanks! but It seems like I have to pay for the license to use greensock :S
Greensock filters are the same thing.
I'm a little unclear what you're trying to do here, and there's some code missing so I can't really play with it. Can you boil down a simple example? The following code creates the "what you want" image but I'm not sure it does it the way you want. Hope it helps!
-Aaron
// create a container
var container:Sprite = new Sprite();
addChild(container);
// draw a circle and put it in the container
var circle:Shape = new Shape();
var g:Graphics = circle.graphics;
g.beginFill(0xff0000);
g.drawCircle(100, 100, 75);
container.addChild(circle);
// draw a blocky mask
var block:Shape = new Shape();
g = block.graphics;
g.beginFill(0);
g.lineTo(100, 0);
g.lineTo(100, 100);
g.lineTo(200, 100);
g.lineTo(200, 200);
g.lineTo(0, 200);
addChild(block);
// apply the mask to the outer container
container.mask = block;
// apply the filter to the inner circle
circle.filters = [new BlurFilter(50, 50)];
// create a bitmap
var bitmap:Bitmap = new Bitmap(new BitmapData(200, 200, true));
bitmap.x = 200;
addChild(bitmap);
// draw that masked and blurred circle to the bitmap
bitmap.bitmapData.draw(container);
Thx for replying. Like you showed me, I tried with Shape as mask object indtead of bitmap. But it did not work either :S
Here is my code:
//create bitmap
var bitmap:Bitmap = new Bitmap(new BitmapData(400,400));
var blur:BlurFilter = new BlurFilter(10, 10);
//create shape
shape.graphics.beginFill(0xff0000, 0.8);
shape.graphics.drawCircle(200,200,100);
//create mask
block.graphics.beginFill(0);
block.graphics.drawCircle(250,200,100);
block.graphics.endFill();
block.cacheAsBitmap = true;
shape.mask = block;
and this is the result:
any idea?
2. Add the shape to the container:
container.addChild(shape);
3. Apply the blur to the shape, and the mask to the container:
3. Draw the container to the bitmap:
That should produce the image you want.
-Aaron
It works! Thanks Aaron!!
Go back to the first response you received to see what it suggested.
Thanks Ned. I appreciate you as well. I could not understand what you suggested but now I can.
