Hot to call import plugin from automation plugin
Sep 12, 2013 1:16 AM
I was able to call filter plug-in from my automation plug-in. Now I'm stuck in calling import plug-in.
I build GradientImport example from PhotoshopSDK, and modify resource PIPL to have unique string ID. ( i.e. I changed this line HasTerminology { plugInClassID, plugInEventID, ResourceID, "" } ) and put a unique ID.
Then I tried to call it from my automation plug-in, but always I get this error: The command "AdobeSDK GradientImport" is not currently available.
What should I change/modify for to be able to call import plug-in (GradientImport is ok) from my automation plug-in ?
Thanks.
    Sep 12, 2013 9:41 AM   in reply to cincirin
    What does script listener give you for your new string change?
    Make sure you right click on .r file and recompile then right click on .rc file and compile when making pipl changes on windows.
    Here is how to call the unmodified version of GradientImport.
    var idImpr = charIDToTypeID( "Impr" );
        var desc1 = new ActionDescriptor();
        var idUsng = charIDToTypeID( "Usng" );
            var desc2 = new ActionDescriptor();
            var idmulK = charIDToTypeID( "mulK" );
                var list1 = new ActionList();
                    var desc3 = new ActionDescriptor();
                    var idVrtc = charIDToTypeID( "Vrtc" );
                    var idshPxl = charIDToTypeID( "#Pxl" );
                    desc3.putUnitDouble( idVrtc, idshPxl, 256.000000 );
                    var idHrzn = charIDToTypeID( "Hrzn" );
                    desc3.putUnitDouble( idHrzn, idshPxl, 256.000000 );
                    var idMdspsp = charIDToTypeID( "Md  " );
                    var idgrmT = charIDToTypeID( "grmT" );
                    var idrgbC = charIDToTypeID( "rgbC" );
                    desc3.putEnumerated( idMdspsp, idgrmT, idrgbC );
                var idmulS = charIDToTypeID( "mulS" );
                list1.putObject( idmulS, desc3 );
            desc2.putList( idmulK, list1 );
        var idgraD = charIDToTypeID( "graD" );
        desc1.putObject( idUsng, idgraD, desc2 );
    executeAction( idImpr, desc1, DialogModes.NO );
    Sep 13, 2013 8:51 AM   in reply to cincirin
    You don't need the stringid to typeid calls. GradientImport is using four character codes and you can use them directly. Here is a C++ version that should work for you. Did the JavaScript version work for you? I got this output from Listener.log.
    SPErr PlayeventImport(/*your parameters go here*/void)
         PIActionDescriptor result = NULL;
         DescriptorTypeID runtimeKeyID;
         DescriptorTypeID runtimeTypeID;
         DescriptorTypeID runtimeObjID;
         DescriptorTypeID runtimeEnumID;
         DescriptorTypeID runtimeClassID;
         DescriptorTypeID runtimePropID;
         DescriptorTypeID runtimeUnitID;
         SPErr error = kSPNoError;
         // Move this to the top of the routine!
         PIActionDescriptor desc00000190 = NULL;
         error = sPSActionDescriptor->Make(&desc00000190);
         if (error) goto returnError;
              PIActionDescriptor desc00000198 = NULL;
              error = sPSActionDescriptor->Make(&desc00000198);
                   PIActionList list00000028 = NULL;
                   error = sPSActionList->Make(&list00000028);
                        PIActionDescriptor desc000001A0 = NULL;
                        error = sPSActionDescriptor->Make(&desc000001A0);
                        error = sPSActionDescriptor->PutUnitFloat(desc000001A0, keyVertical, unitPixels, 256);
                        error = sPSActionDescriptor->PutUnitFloat(desc000001A0, keyHorizontal, unitPixels, 256);
                        error = sPSActionDescriptor->PutEnumerated(desc000001A0, keyMode, 'grmT', 'rgbC');
                   error = sPSActionList->PutObject(list00000028, 'mulS', desc000001A0);
              error = sPSActionDescriptor->PutList(desc00000198, 'mulK', list00000028);
         error = sPSActionDescriptor->PutObject(desc00000190, keyUsing, 'graD', desc00000198);
         error = sPSActionControl->Play(&result, eventImport, desc00000190, plugInDialogSilent);
    returnError:
         if (result != NULL) sPSActionDescriptor->Free(result);
         if (desc00000190 != NULL) sPSActionDescriptor->Free(desc00000190);
         if (desc00000198 != NULL) sPSActionDescriptor->Free(desc00000198);
         if (list00000028 != NULL) sPSActionList->Free(list00000028);
         if (desc000001a0 != NULL) sPSActionDescriptor->Free(desc000001a0);
         return error;
