RonBoyd 118 posts
Jul 19, 2006
Bridge Cache
Sep 13, 2013 4:10 AM
I have a SSHD, too small to accomodate the Bridge Cache, as my C: drive. How can I direct Bridge to use a different Hard Drive?
I can get Bridge (CC version) to create a different Folder in the Preferences menu but have been unable to assign a different hard drive.
    Sep 16, 2013 10:52 AM   in reply to RonBoyd
    Installation Preparations
    read the section about SSDs....
    Mylenium
    Sep 16, 2013 4:43 PM   in reply to RonBoyd
    You can set the path in Bridge Preferences > Cache
    Sep 16, 2013 5:45 PM   in reply to RonBoyd
    Should work as advertised.  Do you see the entire computer drive hieracry in Bridge Folders Panel?  If not reboot computer.
    Sep 16, 2013 9:08 PM   in reply to RonBoyd
    When you click on edit/preferences/cache and then select Browse for cache file location you should see the entire computer file hierachy just like you see if you open Win. Exp.  You should also see this same list if you look in the Panel labeled Folders.  If you do not have folders click on View and check Folders.
    Sep 17, 2013 1:09 AM   in reply to RonBoyd
    Yes, my cache is on my K drive
    Sep 17, 2013 8:42 AM   in reply to RonBoyd
    You need to see the same view that Ronald Keller sees to make this work.
    What OS are you using?  32 or 64 bit?    I see (Main-Vista) are you using Vista?  This may be a problem if so.
    Where do you want the cache to go?
    Sep 17, 2013 9:14 AM   in reply to RonBoyd
    I don't see G on your list above.  Is this a local drive or a networked drive?
    There are some users that have experienced similar problems that have added the missing folder to the Favorites list and then everything is seen in list.  Try that.
    Sep 17, 2013 9:41 AM   in reply to RonBoyd
    Read through these two similar threads and see if you can pick up any hints.
    http://forums.adobe.com/message/4776331
    http://forums.adobe.com/thread/1001556
    Sep 17, 2013 9:55 AM   in reply to Curt Y
    The  xxx1556 link was the one I was thinking of but instead remembered it as Favorites.
    Sep 17, 2013 10:31 AM   in reply to RonBoyd
    For future readers with similar problems was it the 1556 to put a shortcut on desktop for drive?
    Then mark it answered so others will know.
    Sep 17, 2013 10:48 AM   in reply to RonBoyd
    Yes, that works.  Normally you mark the post that has the answer.   Anyone reading the post will see this is the 1st post after the question and won't have to read the entire post to find solution, as least for the OP.   Oddly enough the same solution will not work for everyone.
    You must be on e-mail response as Helpful and Correct are a little more difficult to flag I believe.
