"AdobeFnt13.lst" file missing in the document fonts folder
Sep 13, 2013 6:26 AM
Hello,
I have a bug with Indesign CS5, the "AdobeFnt13.lst" file is now missing in my document fonts folders, even after reinstall of ID.
I deleted the Preferences folder, font cache etc. nothing works so far.
An idea someone ?
    Sep 13, 2013 7:44 AM   in reply to Winston Barbaduc
    I don't believe CS5 added the .lst file. I don't see any sign of one in any of the CS5 packages I've checked.
    Sep 13, 2013 8:17 AM   in reply to Winston Barbaduc
    I just made a new package here for testing in CS5, and it did include the .lst file, but I deleted both the .lst file and the font fom the system fonts folder, and the file opens correctly in both CS5 and CS6, each of which adds back a new .lst file to replace the missing one.
    Sep 16, 2013 5:00 AM   in reply to Winston Barbaduc
    Then you have some other problem, I think.  Try trashing the prefs to see if that helps. See Replace Your Preferences
    Sep 17, 2013 4:43 AM   in reply to Winston Barbaduc
    Try a new user account.
    And which OS are you using?
    Sep 17, 2013 5:50 AM   in reply to Winston Barbaduc
    OK, that rules out a user problem, so now we can look for some sort of system conflict. Reboot holding down the Shift key to disable extensions, launch ID from the regular account, and try, with no other programs running.
    Sep 17, 2013 7:47 AM   in reply to Winston Barbaduc
    Are you fully patched on ID? I'm about out of things to try...
    Sep 17, 2013 8:02 AM   in reply to Winston Barbaduc
    You should be at version 7.0.4
    Cheers!
    -Mikey
