vision_flex
MXML files are corrupted
Sep 14, 2013 11:26 AM
I formated my PC and re-installed Operating System. After that i installed Flash Builder 4.5, When I tried to open the existing FLEX projects, I encountered following problems:
  • The .mxml files show special characters and actual code is replaced by garbage data.
  • 'content is not allowed in prolog' error occurs at compile time because the .mxml data is corrupted
  • Some of the projects cannot be imported in the workspace as the error appears that the folder does not contain valid project file
I am shocked that why the code files are showing strange characters instead of the actual code and why the existing projects are not working fine.
I am looking forward to some way to recover my code files and projects which were working fine previously.
    Sep 15, 2013 8:22 PM   in reply to vision_flex
    Examine the mxml files with a text editor.  Make sure they are corrupted.  I've seen FB get confused by what XML library is used in your version of Java.
    Sep 17, 2013 9:37 AM   in reply to vision_flex
    Not unless there is a pattern to the corruption.
