Ahammed Yunus
convert a webpage to PDF ,the Arabic font does not display ie,blank
Sep 16, 2013 5:49 AM
Tags: #problem #font #acrobat #pdf #adobe #print #convert #blank #webpage
When I trying to convert a webpage to PDF ,the Arabic font does not display ie,blank.how to solve this problem.
    Sep 17, 2013 8:44 AM   in reply to Ahammed Yunus
    Do you have the Language Specific Font Settings set in the HTML Conversion Settings dialog?
    Sep 18, 2013 7:20 AM   in reply to Ahammed Yunus
    In the Create PDF from web page dialog click on the Settings... button and then under Conversion Settings click the Settings button again then choose the language.
    If the HTML page doesn't specificy the encoding, you may want to select that as well in this dialog.
    Sep 18, 2013 9:40 AM   in reply to Ahammed Yunus
    Can you provide a web page link that demonstrates the behavior?
    Sep 19, 2013 3:09 AM   in reply to Ahammed Yunus
    A web link would help. In addition, try printing to the Adobe PDF printer with the Print or Press job settings. Then open the PDF and check the document properties (ctrl-D) under the font tab to see if the font has been embedded. That font table may give the information you need.
