How can I put text on top of a graphic in Framemaker 11?
Sep 16, 2013 4:03 PM
Tags: #images #framemaker_11
I am using Framemaker 11. When I import an image from Photoshop (EPS file) and put a text box on top, I can't get the text to be on top of the graphic without jumping to the next page. Is there a setting that I'm missing in Framemaker? The image is just borders, like a frame, and I'm trying to put the text inside the blank space.
    Sep 16, 2013 4:49 PM   in reply to TechWriterGirl
    Sep 16, 2013 4:51 PM   in reply to TechWriterGirl
    Can you supply a screenshot of what you're trying to do?
    Sep 17, 2013 4:58 AM   in reply to TechWriterGirl
    Possibly you must set the Runaround properties to Don't Run Around. Then the text will stick where it is.
    Sep 17, 2013 10:50 AM   in reply to TechWriterGirl
    You could always use the Textline tool and apply the appropriate character format.
    Sep 17, 2013 11:05 AM   in reply to TechWriterGirl
    I suggest you use the text frame tool (to the left of Arnis' supplied screenshot) and set the background of the text frame (the diagonal b/w lines below the text frame tool) to None.
    When all else fails, add the text to the graphic, save as PDF or other appropriate format, and place as needed.
    -Matt
    Matt R. Sullivan
    co-author Publishing Fundamentals: Unstructured FrameMaker 11
    Sep 17, 2013 12:38 PM   in reply to TechWriterGirl
    It's not clear what the page looks like when it's jumbled.
    Also, in your next screen shot, please turn on View > Text Symbols, and View > Borders, to make troubleshooting a bit less speculative.
    It's possible that there are other currently-invisible items on the page with runaround properties that are affecting the text.
    HTH
    Regards,
    Peter
    _______________________
    Peter Gold
    KnowHow ProServices
