Christina428
Blank recordable CD not recognized by Audition
Sep 16, 2013 4:29 PM
Tags: #help #burning #audition #cds
I have a project that I'm trying to burn onto a CD, but whenever I insert a CD and try and burn it, I get a notice saying that "no media was found in the device."
I've tried using about 3 different CDs, and my computer is capable of both reading and burning CDs using other programs, so I know that the computer is capable of burning CDs.
Any help would be much appreciated.
    Sep 17, 2013 5:18 AM   in reply to Christina428
    Which version of Audition?
    Sep 22, 2013 3:19 AM   in reply to Christina428
    We need to know a bit more about your computer system. Is it a PC or Mac? What operating system are you using? What is the CD burner drive? Which programmes recognise the CD burner?
    If you insert a commercially recorded Cd into the drive can Audition "Extract Audio from CD" in the File menu?
    Nov 25, 2013 6:35 PM   in reply to Christina428
    I'm having the exact same problem. Using Dell XPS 8700, Win8.1. Burner works fine on every other program but Audition. "No media was found in the device. Insert blank recordable CD media, close the tray, then try again.". I've updated drivers, updated audition cc, still nothing.
    Feb 18, 2014 5:06 AM   in reply to captpatch
    I have the same exact issue with a Dell XPS 8700 running Windows 8.1. Has there been any resolution to this issue yet?
    Feb 28, 2014 6:48 PM   in reply to Christina428
    Me too! Same Dell XPS 8700 running Windows 8.1.
    Feb 28, 2014 7:21 PM   in reply to Joe Blackledge
    Okay, that's interesting.  Let's see if we can figure this one out.  Can you go to Search > Device Manager and expose the "DVD/CD-ROM Drives" item and post what the specific brand and model/version your optical drive is?
    Mar 1, 2014 6:36 AM   in reply to _durin_
    HL-DT-ST DVDRWBD CH20N
    That's all it says
    Mar 1, 2014 7:27 AM   in reply to _durin_
    Mine is PLDS DVD+-RW DH 16AES
    Mar 1, 2014 9:02 AM   in reply to _durin_
    Mar 3, 2014 10:47 AM   in reply to captpatch
    I found some information about people experiencing similar issues with the HL-DL-ST drive at http://forums.support.roxio.com/topic/91135-nxt-pro-2-not-recognizing- disc-in-drive/  and similar reports in general with the Dell XPS 8700.  I'm still researching what might be happening, or if these drives may be using a new driver model that may not be supported by the CD Burning engine licensed in Audition.  As soon as I have more information, I'll follow-up.
    Mar 6, 2014 1:30 AM   in reply to Christina428
    I also struggled with the same issue
    I uninstalled "Intel rapid storage" which seems to solved the problem
    Mar 6, 2014 7:00 AM   in reply to AparcheJP
    I just tried the Intel Rapid Storage fix... It didn't work fo rme...
    Mar 12, 2014 10:00 PM   in reply to _durin_
    I am having the same issues with HL-DL-St drives. One is a Pioneer Blue Ray Drive and the other a DVD drive both interfaced using SATA. The Blue Ray Drive worked correctly in my old XP system and then failed to work after I rebuilt the system with a new ASUS 87Z motherboard and updated to 32bit Windows 7. As with the other reports here, neither drive recognizes fresh blank CD media. My work around was to buy a cheap external USB drive also of type HL-DL-ST however this does work correctly using USB. The Pioneer Blue Ray Drive is not type HL-DL-ST to my knowledge.
