kk041480
Error Message "Out of Memory"
Sep 16, 2013 7:09 PM
Tags: #help #error #memory #windows_7 #troubleshooting #flash_cs5 #flash_professional #error_message #out_of_memory
Hi all,
I need your help. I'm in the middle of working on an animatic for an upcoming project in Flash CS5 Professional (64-bit). I'm synching up the drawings to audio, sounds simple enough right? I get about 1/4 of the way into the project and Flash presents me with the error message, "Out of memory."
The file was sent to me by one of my coworkers (working in CS4) and each frame had been drawn using object drawing mode, I broke apart each image and it still doesn't help. I'm working on a piece that is a 10th of a second under 3 mins long and is 16.9mb in size. All I'm doing is shifting the still images to sync up with an audio track.
This is about the 3rd time I've experienced this issue while creating an animatic. I was able to get through the issue the past few times by going into C:\Program Files (x86)\Adobe\Adobe Flash CS5\Common\First Run\ActionScript 3.0 and the jvm text file found there. I upped the alotted RAM from 256 to 500mb and that worked. Then it happened on another project and I upped it again to 1024mb. I would increase the amount again, but I read somewhere that if you go to high (even though you have plenty of available RAM) you could wreck the program even further. I had this problem with Photoshop years ago but was able to go into the programs properites and set the available memory to unlimited, I haven't been able to find something like that for Flash. I've worked on longer more complex programs in Flash without a hitch. I'm stumped!
I need to find some sort of permanent solution and fast!! Thanks in advance!
Version: Flash CS5 Professional (64-bit)
Opperating System: Windows 7 Home Premium
RAM: 4.00GB
HDD Memory: 400GB of 500
File length: 2:50
File size: 16.9mb
    Sep 16, 2013 8:14 PM   in reply to kk041480
    Just to set proper environment, 4GB is bare minimum. Please consider closing every other running app (normal, tray and unnecessary service) before you run Flash.
    Sep 16, 2013 8:17 PM   in reply to sinious
    I can't edit on my phone and not that it helps you but Flash has never been 64bit before Flash CC. That means directly there is no Flash CS5 64bit, it is 32bit.
    Sep 17, 2013 8:39 AM   in reply to kk041480
    Similar to Photoshop, lots of bitmaps (broken apart artwork as you mention) really ramp up the amount of RAM you need for the project. Your project may be 16MB compressed but when it's deflated in memory so you can work on it, it's much larger. Just look at the Flash.exe process and see how much RAM it's currently taking on that project to get an idea of what RAM usage it actually is taking.
    The most important factor of it being a 32bit application as mentioned above is it cannot use more than roughly 3.7GB RAM total. The OS is probably averaging around 1GB ram in use (guessing) leaving you only 3GB RAM (again, guessing) so that isn't an issue for you. But just note that Flash will use all of that 3GB if necessary and available. When you upped the memory limits of jvm.ini you're not upping the amount of RAM Flash itself will use. You're increasing the amount of RAM that the compiler can use when exporting (e.g. AIR apps). Flash doesn't have a memory setting like Photoshop, it will use as much as it needs up to system limits (RAM - physical, available or 32bit).
    Sep 17, 2013 9:55 AM   in reply to kk041480
    If the crashing only happens with other peoples projects it could be for a variety of reasons. There are tons of asset references saved in the library (the location every item was imported from) and much more. None of those locations will exist on your system and internal complications may simply happen, especially with any runtime shared assets.
    If possible you should consider adding more system RAM so you can multi-task. RAM is extremely cheap. I'm assuming from a smaller 500GB HD and 4GB RAM that you're probably on a laptop however. Installing RAM is still usually pretty easy if you have the notebook manual (or grab it online). It typically involves just lifting the keyboard or opening a single panel on the bottom of the notebook but it varies greatly. At any rate, 8GB RAM would help you quite a bit. If you do, just make sure you get the correct type of RAM (again, in the specs in your manual).
    Even when you run out of physical RAM, Flash (like any other application) will still see more RAM based on the OS's swap memory setting (using available space on your HD as RAM). It will get much slower but Flash should see the total amount the 32bit OS can handle for RAM (it doesn't know if it's physical fast RAM or SWAP (fake) HD RAM though). If you open other apps with Flash they should also operate, but will also use swap RAM and you've probably noticed your HD crunching a lot while more apps are open.
    That said, I have a 4GB RAM in my older i7 lappie and have used Flash CS5.5 and CS6 on it extensively, with other applications open. Although my projects contain mild assets and mostly tons of code. No issues at all. I just think your heavy assets are crashing you.
    Either way, glad you got your work done. You're welcome and good luck!
