Crazy Font Issue Saving Book as PDF (Standard Setting in Distiller)
Sep 17, 2013 1:34 PM
I've been trying to track down a crazy font issue all day when exporting my book as a PDF.
When I open FrameMaker, I see the following error each time:
I also see missing font errors in the FrameMaker Console:
And the framemaker book files are not missing fonts:
This is the output I see when I view the PDF:
Please help, as this is running me in to the ground.
Nathan
    Sep 17, 2013 1:52 PM   in reply to Nathan_Anderson
    It looks like you've used Printer fonts.
    In FM, you need to set your default printer to the AdobePDF printer instance (get Sundorne's SetPrint freebie utility for this).
    http://sundorne.com/FrameMaker/Freeware/setPrint.htm
    Sep 18, 2013 10:12 AM   in reply to Nathan_Anderson
    I concur with Arnis. On the Windows platform, Frame constrains itself to the capabilities of the currently configured printer.
    For full access to typography, you need to have a real or virtual PostScript printer configured, and if real, at least a Level 2 color PostScript printer.
    I'm a bit surprised it's apparently possible to Save-As or Print-To PDF with a non-Ps printer currently configured. This would simply fail (or worse) in older versions of FM.
    For more see: Generic / Text Only printer crashes FM10
