Rob774asdasd
Motion Menue transcoded in Encore is jittering even if framerate is correct
Sep 17, 2013 2:33 PM
Tags: #blu-ray #motion #bluray #transcode #framerate #menue
Dear users,
do you experience the same? I have a motion menue encoded in Encore and burnt onto Bluray. I used a quicktime 23.976p file on import as all footage is in 23.976fps as well. Fusion automatically transcoded the file to an m2ts. When I play the Bluray on a hardware player, the motion menue seems to jitter (judder). I check the corresponding m2ts-file in after effects and I see that the framerate seems to be correct, 23.976, but on some frames the video doesn't move, but repeats a frame. How can this be? When source files have all the same framerate?
I am using Encore 5.0 on Windows 7 64bit.
Is this a bug?
Thank you  much.
    Sep 26, 2013 11:35 AM   in reply to Rob774asdasd
    I seem to be having a similar problem, but mine is on DVD with a motion menu. The video, despite the frame rate and conversion method, is rendered as interlaced instead of progressive in Encore. I found this article on Creative Cow that describes my exact issue, and it seems like the issue you are having as well.
    http://forums.creativecow.net/thread/145/870084
