Validating dynamic form
Sep 17, 2013 7:29 PM
Tags: #4.5 #actionscript #form #required #validation #spark_datagrid
I have a Spark DataGrid with data dynamically populated from the database,
so I don't know column count or names.
I need to Add/Edit that data, which I do pulling selected row for edit in dynamic form.
Some of the values on that form are required (extra attribute in DataProvider).
So I need to do required validation of that dynamically built form.
Using Flex 4.5.1
I tried the following:
private function validateRequiredField(field:TextInput):void {
var validator:StringValidator = new StringValidator();
validator.source = "{field}";     <<< Error: source attribute "{field}" can not be of Type String [from mx.validators::Validator/set]
validator.property = "text";
validator.requiredFieldError = "This field is required";
validators.push(validator);
Any idea why I am getting that error above?
I am passing Spark's TextInput control there, not a String.
Calling it in "for" loop going through Dictionary of TextInput object, where Key is column name.
How can I fix it?
TIA,
Oleg.
