DougGator71
My Monitor Blacks Out
Sep 17, 2013 9:29 PM
In a file with several layers, my monitor temporarily blacks out when adjusting colors in a Selective Color adjustment layer.  Is there a solution?
I changed the Advanced Graphics Processor Settings to "Normal" from "Advanced."  Seems better but am I losing performance?
Adobe Photoshop Version: 14.1.1 (14.1.1 20130910.r.414 2013/09/10:23:00:00) x64
Operating System: Windows 8 64-bit
Version: 6.2
System architecture: AMD CPU Family:15, Model:1, Stepping:2 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2
Physical processor count: 3
Logical processor count: 6
Processor speed: 3491 MHz
Built-in memory: 10031 MB
Free memory: 5734 MB
Memory available to Photoshop: 8855 MB
Memory used by Photoshop: 59 %
Image tile size: 132K
Image cache levels: 4
Display: 1
Display Bounds: top=0, left=0, bottom=1050, right=1680
OpenGL Drawing: Enabled.
OpenGL Allow Old GPUs: Not Detected.
OpenGL Drawing Mode: Normal
OpenGL Allow Normal Mode: True.
OpenGL Allow Advanced Mode: True.
NumGPUs=1
gpu[0].OGLVersion="3.0"
gpu[0].MemoryMB=2048
gpu[0].RectTextureSize=16384
gpu[0].Renderer="AMD Radeon HD 7570"
gpu[0].RendererID=26461
gpu[0].Vendor="ATI Technologies Inc."
gpu[0].VendorID=4098
gpu[0].HasNPOTSupport=1
gpu[0].DriverVersion="9.12.2.3000"
gpu[0].Driver="aticfx64.dll,aticfx64.dll,aticfx64.dll,aticfx32,aticfx3 2,aticfx32,atiumd64.dll,atidxx64.dll,atidxx64.dll,atiumdag,atidxx32,at idxx32,atiumdva,atiumd6a.cap,atitmm64.dll"
gpu[0].DriverDate="20130219000000.000000-000"
gpu[0].CompileProgramGLSL=1
gpu[0].TestFrameBuffer=1
gpu[0].OCLSupported=1
gpu[0].OCLVersion="1.2 AMD-APP (938.2)"
gpu[0].CUDASupported=0
gpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="4.20"
gpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTR UCTIONS_ARB]=[2147483647]
gpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[8]
gpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[32]
gpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[16]
gpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[16]
gpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
gpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[16384]
gpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[16384]
gpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[128]
gpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[29]
gpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
gpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
gpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
gpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
gpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
gpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
gpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
gpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
gpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
gpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
Serial number: 96040390238615284014
Application folder: C:\Program Files\Adobe\Adobe Photoshop CC (64 Bit)\
Temporary file path: C:\Users\Doug\AppData\Local\Temp\
Photoshop scratch has async I/O enabled
Scratch volume(s):
  J:\, 931.5G, 800.4G free
Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC (64 Bit)\Required\Plug-Ins\
Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC (64 Bit)\Plug-ins\
Installed components:
   ACE.dll   ACE 2013/07/14-12:09:50   79.543790   79.543790
   adbeape.dll   Adobe APE 2013/02/04-09:52:32   0.1160850   0.1160850
   AdobeLinguistic.dll   Adobe Linguisitc Library   7.0.0
   AdobeOwl.dll   Adobe Owl 2013/03/03-12:10:08   5.0.13   79.533484
   AdobePDFL.dll   PDFL 2013/03/13-12:09:15   79.499517   79.499517
   AdobePIP.dll   Adobe Product Improvement Program   7.0.0.1786
   AdobeXMP.dll   Adobe XMP Core 2013/03/13-12:09:15   79.151481   79.151481
   AdobeXMPFiles.dll   Adobe XMP Files 2013/03/13-12:09:15   79.151481   79.151481
   AdobeXMPScript.dll   Adobe XMP Script 2013/03/13-12:09:15   79.151481   79.151481
   adobe_caps.dll   Adobe CAPS   7,0,0,21
   AGM.dll   AGM 2013/07/14-12:09:50   79.543790   79.543790
   ahclient.dll    AdobeHelp Dynamic Link Library   1,8,0,31
   aif_core.dll   AIF   5.0   79.534508
   aif_ocl.dll   AIF   5.0   79.534508
   aif_ogl.dll   AIF   5.0   79.534508
   amtlib.dll   AMTLib (64 Bit)   7.0.0.169 BuildVersion: 7.0; BuildDate: Mon Apr 8 2013 2:31:50)   1.000000
   ARE.dll   ARE 2013/07/14-12:09:50   79.543790   79.543790
   AXE8SharedExpat.dll   AXE8SharedExpat 2011/12/16-15:10:49   66.26830   66.26830
   AXEDOMCore.dll   AXEDOMCore 2011/12/16-15:10:49   66.26830   66.26830
   Bib.dll   BIB 2013/07/14-12:09:50   79.543790   79.543790
   BIBUtils.dll   BIBUtils 2013/07/14-12:09:50   79.543790   79.543790
   boost_date_time.dll   DVA Product   7.0.0
   boost_signals.dll   DVA Product   7.0.0
   boost_system.dll   DVA Product   7.0.0
   boost_threads.dll   DVA Product   7.0.0
   cg.dll   NVIDIA Cg Runtime   3.0.00007
   cgGL.dll   NVIDIA Cg Runtime   3.0.00007
   CIT.dll   Adobe CIT   2.1.6.30929   2.1.6.30929
   CITThreading.dll   Adobe CITThreading   2.1.6.30929   2.1.6.30929
   CoolType.dll   CoolType 2013/07/14-12:09:50   79.543790   79.543790
   dvaaudiodevice.dll   DVA Product   7.0.0
   dvacore.dll   DVA Product   7.0.0
   dvamarshal.dll   DVA Product   7.0.0
   dvamediatypes.dll   DVA Product   7.0.0
   dvaplayer.dll   DVA Product   7.0.0
   dvatransport.dll   DVA Product   7.0.0
   dvaunittesting.dll   DVA Product   7.0.0
   dynamiclink.dll   DVA Product   7.0.0
   ExtendScript.dll   ExtendScript 2013/03/21-12:10:31   79.535742   79.535742
   FileInfo.dll   Adobe XMP FileInfo 2013/03/19-12:09:02   79.151561   79.151561
   filter_graph.dll   AIF   5.0   79.534508
   icucnv40.dll   International Components for Unicode 2011/11/15-16:30:22    Build gtlib_3.0.16615
   icudt40.dll   International Components for Unicode 2011/11/15-16:30:22    Build gtlib_3.0.16615
   imslib.dll   IMSLib DLL   7.0.0.116
   JP2KLib.dll   JP2KLib 2013/02/19-12:28:44   79.248139   79.248139
   libifcoremd.dll   Intel(r) Visual Fortran Compiler   10.0 (Update A)
   libiomp5md.dll   Intel(R) OMP Runtime Library   5.0
   libmmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   12.0
   LogSession.dll   LogSession   2.1.2.1785
   mediacoreif.dll   DVA Product   7.0.0
   MPS.dll   MPS 2013/03/15-13:25:52   79.535029   79.535029
   msvcm80.dll   Microsoft® Visual Studio® 2005   8.00.50727.6910
   msvcm90.dll   Microsoft® Visual Studio® 2008   9.00.30729.1
   msvcp100.dll   Microsoft® Visual Studio® 2010   10.00.40219.1
   msvcp80.dll   Microsoft® Visual Studio® 2005   8.00.50727.6910
   msvcp90.dll   Microsoft® Visual Studio® 2008   9.00.30729.1
   msvcr100.dll   Microsoft® Visual Studio® 2010   10.00.40219.1
   msvcr80.dll   Microsoft® Visual Studio® 2005   8.00.50727.6910
   msvcr90.dll   Microsoft® Visual Studio® 2008   9.00.30729.1
   PatchMatch.dll   PatchMatch 2013/06/11-12:08:08   79.542390   79.542390
   pdfsettings.dll   Adobe PDFSettings   1.04
   Photoshop.dll   Adobe Photoshop CC   CC
   Plugin.dll   Adobe Photoshop CC   CC
   PlugPlugOwl.dll   Adobe(R) CSXS PlugPlugOwl Standard Dll (64 bit)   4.0.1.34
   PSArt.dll   Adobe Photoshop CC   CC
   PSViews.dll   Adobe Photoshop CC   CC
   SCCore.dll   ScCore 2013/03/21-12:10:31   79.535742   79.535742
   ScriptUIFlex.dll   ScriptUIFlex 2013/03/21-12:10:31   79.535742   79.535742
   svml_dispmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   12.0
   tbb.dll   Intel(R) Threading Building Blocks for Windows   4, 1, 2012, 1003
   tbbmalloc.dll   Intel(R) Threading Building Blocks for Windows   4, 1, 2012, 1003
   updaternotifications.dll   Adobe Updater Notifications Library   7.0.1.102 (BuildVersion: 1.0; BuildDate: BUILDDATETIME)   7.0.1.102
   WRServices.dll   WRServices Mon Feb 25 2013 16:09:10   Build 0.19078   0.19078
Required plug-ins:
   3D Studio 14.1.1 (14.1.1 x001)
   Accented Edges 14.1.1
   Adaptive Wide Angle 14.1.1
   Angled Strokes 14.1.1
   Average 14.1.1 (14.1.1 x001)
   Bas Relief 14.1.1
   BMP 14.1.1
   Camera Raw 8.2
   Camera Raw Filter 8.2
   Chalk & Charcoal 14.1.1
   Charcoal 14.1.1
   Chrome 14.1.1
   Cineon 14.1.1 (14.1.1 x001)
   Clouds 14.1.1 (14.1.1 x001)
   Collada 14.1.1 (14.1.1 x001)
   Color Halftone 14.1.1
   Colored Pencil 14.1.1
   CompuServe GIF 14.1.1
   Conté Crayon 14.1.1
   Craquelure 14.1.1
   Crop and Straighten Photos 14.1.1 (14.1.1 x001)
   Crop and Straighten Photos Filter 14.1.1
   Crosshatch 14.1.1
   Crystallize 14.1.1
   Cutout 14.1.1
   Dark Strokes 14.1.1
   De-Interlace 14.1.1
   Dicom 14.1.1
   Difference Clouds 14.1.1 (14.1.1 x001)
   Diffuse Glow 14.1.1
   Displace 14.1.1
   Dry Brush 14.1.1
   Eazel Acquire 14.1.1 (14.1.1 x001)
   Embed Watermark 4.0
   Entropy 14.1.1 (14.1.1 x001)
   Extrude 14.1.1
   FastCore Routines 14.1.1 (14.1.1 x001)
   Fibers 14.1.1
   Film Grain 14.1.1
   Filter Gallery 14.1.1
   Flash 3D 14.1.1 (14.1.1 x001)
   Fresco 14.1.1
   Glass 14.1.1
   Glowing Edges 14.1.1
   Google Earth 4 14.1.1 (14.1.1 x001)
   Grain 14.1.1
   Graphic Pen 14.1.1
   Halftone Pattern 14.1.1
   HDRMergeUI 14.1.1
   IFF Format 14.1.1
   Ink Outlines 14.1.1
   JPEG 2000 14.1.1
   Kurtosis 14.1.1 (14.1.1 x001)
   Lens Blur 14.1.1
   Lens Correction 14.1.1
   Lens Flare 14.1.1
   Liquify 14.1.1
   Matlab Operation 14.1.1 (14.1.1 x001)
   Maximum 14.1.1 (14.1.1 x001)
   Mean 14.1.1 (14.1.1 x001)
   Measurement Core 14.1.1 (14.1.1 x001)
   Median 14.1.1 (14.1.1 x001)
   Mezzotint 14.1.1
   Minimum 14.1.1 (14.1.1 x001)
   MMXCore Routines 14.1.1 (14.1.1 x001)
   Mosaic Tiles 14.1.1
   Multiprocessor Support 14.1.1 (14.1.1 x001)
   Neon Glow 14.1.1
   Note Paper 14.1.1
   NTSC Colors 14.1.1 (14.1.1 x001)
   Ocean Ripple 14.1.1
   Oil Paint 14.1.1
   OpenEXR 14.1.1
   Paint Daubs 14.1.1
   Palette Knife 14.1.1
   Patchwork 14.1.1
   Paths to Illustrator 14.1.1
   PCX 14.1.1 (14.1.1 x001)
   Photocopy 14.1.1
   Photoshop 3D Engine 14.1.1 (14.1.1 x001)
   Photoshop Touch 14.0
   Picture Package Filter 14.1.1 (14.1.1 x001)
   Pinch 14.1.1
   Pixar 14.1.1 (14.1.1 x001)
   Plaster 14.1.1
   Plastic Wrap 14.1.1
   PNG 14.1.1
   Pointillize 14.1.1
   Polar Coordinates 14.1.1
   Portable Bit Map 14.1.1 (14.1.1 x001)
   Poster Edges 14.1.1
   Radial Blur 14.1.1
   Radiance 14.1.1 (14.1.1 x001)
   Range 14.1.1 (14.1.1 x001)
   Read Watermark 4.0
   Reticulation 14.1.1
   Ripple 14.1.1
   Rough Pastels 14.1.1
   Save for Web 14.1.1
   ScriptingSupport 14.1.1
   Shake Reduction 14.1.1
   Shear 14.1.1
   Skewness 14.1.1 (14.1.1 x001)
   Smart Blur 14.1.1
   Smudge Stick 14.1.1
   Solarize 14.1.1 (14.1.1 x001)
   Spatter 14.1.1
   Spherize 14.1.1
   Sponge 14.1.1
   Sprayed Strokes 14.1.1
   Stained Glass 14.1.1
   Stamp 14.1.1
   Standard Deviation 14.1.1 (14.1.1 x001)
   STL 14.1.1 (14.1.1 x001)
   Sumi-e 14.1.1
   Summation 14.1.1 (14.1.1 x001)
   Targa 14.1.1
   Texturizer 14.1.1
   Tiles 14.1.1
   Torn Edges 14.1.1
   Twirl 14.1.1
   Underpainting 14.1.1
   Vanishing Point 14.1.1
   Variance 14.1.1 (14.1.1 x001)
   Variations 14.1.1 (14.1.1 x001)
   Water Paper 14.1.1
   Watercolor 14.1.1
   Wave 14.1.1
   Wavefront|OBJ 14.1.1 (14.1.1 x001)
   WIA Support 14.1.1 (14.1.1 x001)
   Wind 14.1.1
   Wireless Bitmap 14.1.1 (14.1.1 x001)
   ZigZag 14.1.1
Optional and third party plug-ins: NONE
Plug-ins that failed to load: NONE
Flash:
   Kuler
   Adobe Exchange
Installed TWAIN devices: NONE
    Sep 17, 2013 11:47 PM   in reply to DougGator71
    I am using ATI Radeon video driver version 12.104.0.0
    I have found that not all drivers are equal and some will crash your computer. In fact, this version will create a blue screen if you don't change the registry settings manually to allow multiple apps using the driver. HP has instructions on how to alter the registry. I do not know if this issue is HP only, ATI only or affects everyone using that driver.
    I was going to make a joke when i read your subject line.  I wanted to tell you yes it is an easy fix, just take its bottle away. No more black outs. Wahaha...
    But, I figure you needed a bit more help, so...
