Responsive Navigation: How? Best Method?
Sep 17, 2013 11:20 PM
Tags: #responsive_design #navigation_toolbar
I am novice trying to build first site, that is responsive design. I want to create a navigation that works on all platforms (desk,tablet, and mobile), but am unsure as the best way to go about doing this.
To create navigation I know of essentially three ways? :
  • Create (customize) a widget style navigation bar.
  • A html unordered list navigation
  • Create several divs all within a div (each for a menu item).
To avoid alot of frustration and time as a novice designer, does anyone have any suggestions for the best way to implement a navigation bar across all platforms?
Should I also consider using 'display none' in mobile CSS, and use a jquery menu somehow?
Thanks very much for any help.
Any advice for aligning a 'responsvie' footer would be appreciated.
http://forums.adobe.com/message/5691602#5691602
    Sep 18, 2013 12:13 AM   in reply to dreamweaver70
    You can implement this in your site:
    http://responsive-nav.com/
    http://jasonweaver.name/lab/flexiblenavigation/
    Just follow the instructions on the websites.
    I don't think your able as a novice to design something like this!
    Or if you want to spend $ 95 for a extension that spits it out in Dreamweaver where you want it:
    http://projectseven.com/products/menusystems/pmm3/index.htm
    Sep 18, 2013 11:30 AM   in reply to dreamweaver70
    I use a CSS styled list menu along with a free jQuery plugin called MeanMenu.
    You can see it working below:
    http://alt-web.com/FluidGrid/Fluid2.html
    Nancy O.
    Sep 18, 2013 1:01 PM   in reply to dreamweaver70
    Look at the demo.html file that came with your MeanMenu download.  You'll notice it uses <ul> and <li> tags as hooks for the CSS and JavaScript code.  So yes, you need to use a list menu.
    Nancy O.
    Sep 19, 2013 11:59 AM   in reply to dreamweaver70
    • I see no links to the jQuery core library
    • No links to MeanMenu.js
    • No links to MeanMenu.css
    • No list menus.
    • And no jQuery function codes.
    Maybe that's why your plugin doesn't work.
    Nancy O.
