High CPU and memory usage after Add-in update to 11.2.385.0
Sep 18, 2013 2:28 AM
Tags: #issue #adobe #9 #problems #add-in
After last update Add-in leaks memory when switching layouts and has high CPU usage (90-100%) all the time on more than 20 computers running different browsers, OSes etc. What can we do to make our environment usable again?
(we use adobe connect hosted option ver. 9.1.1, add-in version is WIN11.2.385.0)
    Sep 18, 2013 10:52 AM   in reply to Łukasz Jakóbiec
    We are an on-premise environment and currently using Connect Add-in 11.2.385.0 and are on v9.0.4.  We have 8 App servers and each is experiencing high cpu usage as of late.
    Is this in relation to the Add-In 11.2.385.0 and what is being done to address this issue?
    Sep 18, 2013 12:01 PM   in reply to dkrobbins
    Several people on our team have been complaining about 11.2.385.0,
    crashes and systems driven to 100% CPU usage.
    Also we have seen machines heating up 10-20 degrees instantly when AdobeConnectAddIn.EXE is running, with temp running to 100 Celcius.
    No other significant software is running on the machine, you will note
    most other apps are on idle.
    Soon after on this machine temps jumped to 100 and the machine shut down.
    Sep 19, 2013 3:22 AM   in reply to Łukasz Jakóbiec
    Hi Lucasz et al,
    Can you please provide some info on the screen Resolution of the machien which is having this issue ?
    (Assuming the CPU usage you have mentioned is with screen sharing) Also it would be great if you could describe a bit about :
    a) CPU usage when nothing is being shared
    b) And when one shares the screen
    Regards
    Nikhil
    Sep 19, 2013 4:09 AM   in reply to Łukasz Jakóbiec
    We experience the same thing as Lukasz reports.
    We have seen CPU temp on machines climb from 55 degrees C to
    100 degrees C within 5 minutes of loading AdobeConnectAddIn.EXE on several occassions, that is with or without screen sharing, with AdobeConnectAddIn.EXE clearly using between 50-80% of CPU from point of startup.
    We have seen CPU demand for AdobeConnectAddIn.EXE jump to 80%,
    as soon as sharing MS WORD, but can't say would not happen without screen
    sharing because we have seen the high CPU usage happen without screen sharing.
    In general AdobeConnectAddIn.EXE aggressively consumes most or all available CPU driving general CPU use to 100% (ceiling usage).   This only began with ver. 11.2.385.0,
    Our team has been have using Adobe connect intensively for 3 years w/o this sort of problem until ver. 11.2.385.0, was forced in Adobe connect upgrade window in the last 7-10 days.
    Per screen resolution - 1200X1920
    CPU Usage - 50% to 80% + experienced when loading add-in.
    CPU heat increases - 40degrees celsius within 5 - 8 minutes of loading add-in.
    Other : We do not use video or audio features of Adobe Connect.
    Our primary desktop sharing is limited to MS Office and text based information sharing.
    Sep 19, 2013 4:13 AM   in reply to MarkAnthony2014
    This issue is also mentioned in the following thread
    http://forums.adobe.com/message/5678222
    Sep 19, 2013 4:35 AM   in reply to MarkAnthony2014
    I expereinced the same. I think the add-in should be updated as soon as possible.
    Sep 19, 2013 5:09 AM   in reply to David Roethler
    Using Windows CPU Usage history this is what we see.
    1. A machine idle with no desktop apps running.
    2. Small spike as IE is loaded.
    3. Big CPU usage spike pounds cieling of metrics reading as soon as   AdobeConnect is loaded.
    4. CPU usage spike continues until AdobeConnectAddIn.Exe is closed.
    No other applications running.
  • Sameer Puri
    May 21, 2013
    Sep 19, 2013 6:31 AM   in reply to MarkAnthony2014
    Hi Mark/David,
    We are sorry for the issue that you are facing with the new addin, but trust us we are working to get this resolved. Problem is that we weren't able to reproduce the problem in-house. As Tushar mentioned in the other thread, maximum CPU usage that we see is around 30% and that too while Screen Sharing. Also we havent seen any issue of memory leaks happening while changing the layouts.
    We will really appreciate if everybody who is facing the issue can tell us their Machine make and other details(OS, RAM, Processor etc etc). We will try to get a similar machine and then try to reproduce the issue.
    Hopefully we should be able to fix this soon!
    Sameer Puri
    Sep 19, 2013 6:47 AM   in reply to Sameer Puri
    Hi Sameer,
    Thank you very much for your message! You can find information about my machine at http://forums.adobe.com/message/5678222#5678222
    But as I wrote before it seems to be independent from a specific configuration as my other computers and my colleagues face the same issue.
    Best wishes,
    David
    Sep 19, 2013 7:03 AM   in reply to David Roethler
    Windows 7 Pro 64bit
    Intel(R) Core(TM) I7 m640 2.80GHZ
    8 GB Ram
    120 GB SSD drive.
    Nvidia Quadro
    As mentioned above, this is one machine - others on our team are having the same
    problem with various Windows 7 configurations.
  • Sameer Puri
    May 21, 2013
    Sep 19, 2013 7:06 AM   in reply to MarkAnthony2014
    Thank you so much for this info. Every bit of information is Gold dust for us. We will try to arrange similar models of machine and then try to reproduce the issue. Will keep you are updated.
    Thanks again!
    Sameer Puri
    Sep 19, 2013 10:51 AM   in reply to Łukasz Jakóbiec
    Hi there,
    I am having the same problem.
    Case number: 0184702770
    Adobe has sent me generic instructions on decreasing screen resolution, cleanup desktop, blah blah which is not helpful. My machine has been running fine with Acrobat Connect for four years and suddenly this problem appears. It does not happen on another machine with same screen res, network connection, etc. however it is running Win Server 2008 R2.
    Here is my configuration and screen shot of task manager and resources monitor showing connect consuming bandwidth and being non-reponsive:
    Oct 10, 2013 7:23 AM   in reply to Sameer Puri
    Its been nearly a month since this problem was first described in detail by IT professionals
    on these forum pages.
    Still I need to place 3 additional fans on my workstation and use a third party application called
    Process Tamer in order to use Adobe Connect.
    This is after 2 years of constant Adobe connect usage on the same computer, without any of this additional 3rd party and extra fans to make Adobe connect to work.
    As mentioned before this is on an HP Elitebook, Windows 7 Pro, with latest Windows updates,
    latest bios and video drivers from HP.
    The problem is clearly the Adobe Software, there is obviously a memory leak or other resource grabbing bug in the application.
    Our company has posted 2 tickets to adobe support on this and yet we have no functional reply or suggestions.
    As defined here the problem is scientifically traceable to use of the Adobe Connect update
    Connect Add-in 11.2.385.0 .
    Initially we went though 3 tiers of tech support, most of who refused to
    admit the problem existed at all. This is while internet chatter and discussions
    on this forum both were already findable on Google.
    Is there any status on a resolution yet from Adobe to the CPU issue?
  • Sameer Puri
    May 21, 2013
    Oct 10, 2013 11:15 AM   in reply to MarkAnthony2014
    Hi Mark et al,
    Apologies that this issue is still troubling you. But trust me, we are working hard to find a solution to this one. Biggest obstacle in front of us is the absence of a machine where the issue reproduces.
    To counter that we have started having meetings with the customers facing this issue so that we can have our hands on their machines. Since so many people are facing this issue, we cant deny that there is a issue somewhere. Please bear with us while we try to isolate the problem and present a solution.
    Sameer Puri
  • Sameer Puri
    May 21, 2013
    Oct 17, 2013 12:31 AM   in reply to Łukasz Jakóbiec
    Hi All,
    Good News! We were able to reproduce the issue in-house and have started working on the fix now. Though i dont have any ETA about when this fix will be available to in an update, but be rest assured that whenever it will be provided(should be soon), it will fix the issue forever.
    Stay tuned for other updates!
    Sameer Puri
    Oct 17, 2013 10:59 PM   in reply to Łukasz Jakóbiec
    Hi All,
    There is a workaround to resolve this issue. As it is related to modifying registry, please be very careful and take backup of your registry first.
    The workaround is to set the value of "Disable Performance Counters" to 0 @ HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\PerfProc\Performa nce
    If this registry entry is not present, create one. Meanwhile, we are working on fixing this issue.
    Hope this helps!
    Deepika
    PS: Edit the Registry at your own risk. Inappropriate changes to the Windows Registry can disable the operating system! To safeguard against such an accident, back up your existing registry by choosing Registry » Export Registry File after launching the Registry Editor and before making any changes
    Oct 18, 2013 3:47 AM   in reply to Łukasz Jakóbiec
    Thanks for the update Lukasz!
    It is good to know that your CPU usage drops to 1% after applying the workaround.
    To sum up, for Connect add-in to consume less CPU, as a workaround the performance monitor library needs to be rebuilt and "perfproc" provider should be enabled as follow:
    "Click Start, type cmd right click cmd.exe, and select Run as administrator.
    At the prompt, type lodctr /r and press ENTER. This will repair the pointers (those are stored in the registry).
    C:\Windows\system32>lodctr /r
    Info: Successfully rebuilt performance counter setting from system backup store
    After this action it is possible that perfproc providers are disabled. You can check the status with lodctr /q.
    C:\Windows\system32>lodctr /q
    Performance Counter ID Queries [PERFLIB]:
    etc...
    If it says (Disabled) next to perfproc  provider, you can enable it with lodctr /e:perfproc "
    Oct 28, 2013 10:55 AM   in reply to Łukasz Jakóbiec
    This fix does not work on my machine either Windows 7 English version.. No noticable difference on changing registry.
    Oct 29, 2013 12:27 AM   in reply to MarkAnthony
    Hi Mark,
    I hope you have executed the "lodctr" utility along with the regisrtry changes, as described in my last post. This should surely fix the CPU spike issue on Windows English locale.
    Deepika
    Nov 18, 2013 9:59 PM   in reply to Łukasz Jakóbiec
    Good News!
    The new add-in 11.2.392.0 is available with the fix. Please un-install your older add-in and install the new add-in from follwoing location or directly from the meeting:
    http://www.adobe.com/go/adobeconnect_9_addin_win
    http://www.adobe.com/go/adobeconnect_9_addin_mac
    Deepika
    Feb 16, 2014 11:59 PM   in reply to Deepika Mangal
    Hi, i install the new add-in 949, but we still have the same problems. This happens since i use windows 8
  • Sameer Puri
    May 21, 2013
    Feb 17, 2014 12:10 AM   in reply to xavicn
    Hi xavicn,
    The issue was fixed with 11.2 build of addin.. Are you saying that the issue re-appeared in 11.9.949.0? Are you facing the exact same issue as mentioned above in the mail thread??
    ~Sameer Puri
    Feb 17, 2014 12:39 AM   in reply to Sameer Puri
    Yes, when i open 1 meeting, the CPU works at 50-60%, and when i open 2 or more meetings CPU works at 100%, and i can't work.
    We have Connect server 9.0 and the users windows 8 with the last add-in
    Thnks
  • Sameer Puri
    May 21, 2013
    Feb 17, 2014 2:10 AM   in reply to xavicn
    Hi xavicn,
    Have you tried steps mentioned by Deepika in one of the above comments:
    etc...
    Also, can you please let us know the locale of your Windows OS? Is it English or any other language?
    ~Sameer Puri
    Feb 17, 2014 3:39 AM   in reply to Sameer Puri
    Yes, i have tried the steps, but the result is the same 99% of CPU
    Windows' lenguage is Spanish or Catalan
