DJH_EOS
How do I reference the data object in a DataGrid to show an image correctly in Acrobat?
Sep 19, 2013 12:00 PM
Tags: #error #xml #4.5 #spark #flex4.5
I'm creating an inferface for an Acrobat application  and I'm having a issue with displaying an image in a grid.  When I hard code the source="statusNONE.png" it works as intended (with an image, not the image associated with each grid item), however, when I try to use the source="{data.@icon}" to reference the dataProvider (XMLListCollection) I get nothing.  Not a broken image or anything.  I think I may just not be referencing the XMLListCollection correctly, otherwise I don't know why it would work with hard coding vs. fetching the string from the XML.
//Application Header (Flex 4.5)
                                 xmlns:mx="library://ns.adobe.com/flex/mx"
                                 width="100%" height="100%" creationComplete="eaton_creationCompleteHandler(event)"
                                 currentState="Review">
//Sample of XML that gets used as basis for XMLListCollection
<Annots>
     <Annot name='TEST' index='14' feedback='' canConstruct='0' icon='statusNONE.png'/>
</Annots>
//creation of the XMLListCollection from String
[Bindable] protected var fullXML:XML;
[Bindable] protected var fullXMLCol:XMLListCollection;
protected function loadXML(xmlString:String):void
      fullXML = new XML(xmlString);
     var fullXMLList:XMLList = fullXML.children();
      fullXMLCol = new XMLListCollection(fullXMLList);
//DataGrid
<s:DataGrid left="0" top="0" bottom="0" width="142" dataProvider="{fullXMLCol}"
                                        requestedRowCount="4" rowHeight="30"
                                        top.Confirm="87">
                    <s:columns>
                              <s:ArrayList>
                                        <s:GridColumn dataField="@name" headerText="Annotations"></s:GridColumn>
                                        <s:GridColumn headerText="status" width="30" >
                                                  <s:itemRenderer>
                                                            <fx:Component>
        <s:GridItemRenderer>
        <s:Image width="30" height="30" source="{data.@icon}"/> //THIS IS THE PART THAT SEEMS TO BE GIVNG ME TROUBLE!
        </s:GridItemRenderer>
                                                            </fx:Component>
                                                  </s:itemRenderer>
                                        </s:GridColumn>
                              </s:ArrayList>
                    </s:columns>
                    <s:typicalItem>
                              <fx:Object dataField1="Sample Data" dataField2="Sample Data" dataField3="Sample Data"></fx:Object>
                    </s:typicalItem>
          </s:DataGrid>
Additional information.  I'm using the resources tab for the flash embedding in Acrobat for my images. This works when I am hard coding the file name string works for the source without having to add a full path, the images are not technically bundled into the swf.   I just don't understand why using the data object to get that same string would show different results.
tl;dr: GridItemRenderer works to show images when hard coded but not when using {data}.
UPDATE: Figured it out, needed to add a toString() to the data.@icon.   I had assumed it was a string being handed over, I assumed wrong.
    Sep 19, 2013 1:36 PM   in reply to DJH_EOS
    Probably because data.@icon isn't a String, it is an XMLList, and source property is an Object not a String so the runtime doesn't automatically convert it.
      Try data.@icon.toString()
