WCoder
Problem with invalid /Pages on root obj...
Sep 19, 2013 2:10 AM
Tags: #xref #pages #page #startxref
Document : http://6m889f.1fichier.com/ - 28Kb - No script - No crypt (can be open with wordpad).
The document is an extract of a page of a big document that seems to be done with acrobat, so i suppose the doc is valid but my undestanding of PDF32000_2008 is wrong...
The page contain only an image type : CCITTFaxDecode.
The mecanisme i use to decode the doc :
1 - Extract start xref from the doc (read from end)
startxref
116
%%EOF
2 - Move to offset 116
20 0 obj
        /DecodeParms
            <</Columns 4/Predictor 12>>
        /Filter/FlateDecode
        /ID[<9D591874D8530F47922A2947626F4B0A><6D9DBF0DD389B440AC6E086693CE9B 16>]
        /Index[11 19]
        /Info 10 0 R    <- This entry don't exist.
        /Length 59
        /Prev 27626
        /Root 12 0 R    <- This entry exist.
        /Size 30
        /Type/XRef/W[1 2 1]
stream...endstream...endobj
a - I have an other xref at offset 27626
b - /Info ref to an obj that is not visible on the PDF document ?
c - /Root ref to a valid obj.
3 - I decode xref
Message - Process XRef - Offset 116
---------------------------------------------------------------------- -< Begin of first cross-reference stream
Message - Process type 1 :  Dump Data ( 4 ): 01 00 10 00
Message - Add new XRef 11 - Offset 16        <- Match with file
Message - Process type 1 :  Dump Data ( 4 ): 01 02 6C 00
Message - Add new XRef 12 - Offset 620        <- Match with file
Message - Process type 1 :  Dump Data ( 4 ): 01 02 B9 00
Message - Add new XRef 13 - Offset 697        <- Match with file
Message - Process type 1 :  Dump Data ( 4 ): 01 04 45 00
Message - Add new XRef 14 - Offset 1093        <- Match with file
Message - Process type 1 :  Dump Data ( 4 ): 01 06 3B 00
Message - Add new XRef 15 - Offset 1595        <- Match with file
Message - Process type 1 :  Dump Data ( 4 ): 01 07 EF 00
Message - Add new XRef 16 - Offset 2031        <- Match with file
Message - Process type 1 :  Dump Data ( 4 ): 01 08 B2 00
Message - Add new XRef 17 - Offset 2226        <- Match with file
Message - Process type 1 :  Dump Data ( 4 ): 01 09 3F 00
Message - Add new XRef 18 - Offset 2367        <- Match with file
Message - Process type 1 :  Dump Data ( 4 ): 01 0A 78 00
Message - Add new XRef 19 - Offset 2680        <- Match with file
Message - Process type 1 :  Dump Data ( 4 ): 01 00 74 00
Message - Add new XRef 20 - Offset 116        <- Match with file (this entry)
Message - Drop type 2 :  Dump Data ( 4 ): 02 00 0E 00    <- ?
Message - Drop type 2 :  Dump Data ( 4 ): 02 00 0E 01     <- ?
Message - Drop type 2 :  Dump Data ( 4 ): 02 00 0E 02     <- ?
Message - Drop type 2 :  Dump Data ( 4 ): 02 00 0E 03     <- ?
Message - Drop type 2 :  Dump Data ( 4 ): 02 00 0E 04     <- ?
Message - Drop type 2 :  Dump Data ( 4 ): 02 00 0E 05     <- ?
Message - Drop type 2 :  Dump Data ( 4 ): 02 00 0E 06     <- ?
Message - Drop type 2 :  Dump Data ( 4 ): 02 00 0E 07     <- ?
Message - Process type 1 :  Dump Data ( 4 ): 01 01 CE 00
Message - Add new XRef 21 - Offset 462
---------------------------------------------------------------------- -< End of first cross-reference stream
  a - All entries start with 01 : Is valid and is a the offset.
  b - I have some starting with 02
      I don't really undestand the document about this entry
     The solution seems to be on Table 18 –  Entries in a cross-reference stream
      I suppose first byte (w:121) is the type Type 2 (first column of the table )
      For 000E and 07 i don't undestand....
      I will see that point later except if it the solution to my problem ^_^...
4- I decode the second xref
  a -  Move to offset 27626 ( /Prev 27626 )
5 0 obj<<
/DecodeParms<</Columns 4/Predictor 12>>
/Filter/FlateDecode/ID[<9D591874D8530F47922A2947626F4B0A><6D9DBF0DD389 B440AC6E086693CE9B16>]
/Info 10 0 R<- Like in previousely, this entry don't exist.
/Length 49
/Root 12 0 R<- Like in previousely, this entry exist.
/Size 11
/Type/XRef/W[1 2 1]
b - decoding
---------------------------------------------------------------------- -< begin of second cross-reference stream
Message - Drop type 0 :  Dump Data ( 4 ): 00 00 00 00    <- ?
Message - Process type 1 :  Dump Data ( 4 ): 01 5B 2A 00
Message - Add new XRef 1 - Offset 23338        <- Match with file (this entry)
Message - Process type 1 :  Dump Data ( 4 ): 01 5E 01 00
Message - Add new XRef 2 - Offset 24065        <- Match with file (this entry)
Message - Process type 1 :  Dump Data ( 4 ): 01 6A 83 00
Message - Add new XRef 3 - Offset 27267        <- Match with file (this entry)
Message - Process type 1 :  Dump Data ( 4 ): 01 6B 10 00
Message - Add new XRef 4 - Offset 27408        <- Match with file (this entry)
Message - Process type 1 :  Dump Data ( 4 ): 01 6B EA 00
Message - Add new XRef 5 - Offset 27626        <- Match with file (this entry)
Message - Drop type 2 :  Dump Data ( 4 ): 02 00 01 00    <- ?
Message - Drop type 2 :  Dump Data ( 4 ): 02 00 01 01    <- ?
Message - Drop type 2 :  Dump Data ( 4 ): 02 00 01 02     <- ?
Message - Drop type 2 :  Dump Data ( 4 ): 02 00 03 00    <- ?
Message - Drop type 2 :  Dump Data ( 4 ): 02 00 04 00    <- ?
---------------------------------------------------------------------- -< End of second cross-reference stream
     same issue than for previous xref.
So now i have a vector of all obj on the document there no orphan,  it's why i don't investigate for strange entry 02.
5 - Read root entry
12 0 obj<<
/AcroForm 21 0 R
/Metadata 2 0 R
/Pages 9 0 R<- This entry to not exist
/Type/Catalog
endobj
As previous with /Info 10 0 R that don't exist on the document, /Pages 9 0 R don't exist on document ?!
The document can be read by acrobat-reader & foxit, so i do something wrong but i don't see what...
The only obj with "page" is :
13 0 obj
     <<     /BleedBox[29.9391 30.0045 681.297 871.951]
              /Contents 15 0 R
              /CropBox[29.9391 30.0045 681.297 871.951]
              /MediaBox[0 0 711.968 901.89]
              /Parent 9 0 R
              /Resources<</ColorSpace<</CS0 22 0 R/CS1 23 0 R>>/ExtGState<</GS0 24 0 R/GS1 25 0 R>>
              /Font<</T1_0 28 0 R>>
              /ProcSet[/PDF/Text/ImageC]
              /XObject<</Im0 19 0 R>>
     /Rotate 0
     /StructParents 57
     /TrimBox[29.9391 30.0045 681.297 871.951]
     /Type/Page
endobj
And "/Parent 9 0 R" this the same issue than with root : It's not on the doc ?
If someone can help me ?
WCoder
Message was edited by: WCoder - Firefox crash + correction+add pdf...
    Sep 19, 2013 2:31 AM   in reply to WCoder
    I have not looked into the details of your post but have one question for you: are you aware of (and understand) compressed object streams?
    Olaf
    Sep 19, 2013 3:37 AM   in reply to WCoder
    No, that's not what he meant. Object streams, 7.5.7. Cross reference streams, 7.5.8.
    Sep 19, 2013 3:46 AM   in reply to WCoder
    No, I was referring to "compressed object streams", as defined in IUSO 32000-1, "7.5.7 Object Streams". Are you familiar with that chapter?
    Olaf
    Am 19 Sep 2013 um 12:33 schrieb WCoder <forums_noreply@adobe.com>:
    Re: Problem with invalid /Pages on root obj...
    created by WCoder in PDF Language and Specifications - View the full discussion
    If you speak about : <</Filter/FlateDecode - Yes i already do this part of job you can do this using zlib and inflate function.
    I use v1.2.8 from http://www.zlib.net/
    Pseudo code.
    z_stream oZStream;
    Zero memory : oZStream
    // Set input buffer :
    oZStream.avail_in <= size imput buffer read from "/Length 407"    + 1   (see pitfall)
    oZStream.next_in <= input buffer (pointer)  (see pitfall)
    // Set output buffer (append).
    oZStream.avail_out <= max size of output buffer (i use a static buffer of 16Mo - i don't already optimize this point).
    oZStream.next_out <= output buffer (pointer)
    // Init unpack
    if ( Z_OK == ( lResult = inflateInit ( &oZStream )))
    // Unpack : In one time for me i have a big ... buffer _
    if ( 0 <= ( lResult = inflate ( &oZStream, Z_FINISH )))
    // Finalize operation.
    inflateEnd ( &oZStream );
    Warning there's a pitfalls :
    A - the begin and the end of the stream.
    32392030206F626A0D3C3C2F46696C7465722F466C61          29 0 obj.<</Filter/Fla
    74654465636F64652F492039392F4C656E6774682037            teDecode/I 99/Length 7
    342F532033382F562037373E3E73747265616D0D0A68           4/S 38/V 77>>stream..h             // Stream start after stream and after 0D0A (line separator)
    865003544BB4168466BA0ED7C4C2C0902D0035F01640          .P.TK...f.......-.5..@
    80010072E908100D0A656E6473747265616D                              ...r.....endstream                      // Stream end before endstream and before ODOA (line separator)
    B - The size of the input buffer, i need to increst it by one, i don't undestand why but it's work !?
    WCoder
    Please note that the Adobe Forums do not accept email attachments. If you want to embed a screen image in your message please visit the thread in the forum to embed the image at http://forums.adobe.com/message/5695533#5695533
    Replies to this message go to everyone subscribed to this thread, not directly to the person who posted the message. To post a reply, either reply to this email or visit the message page: Re: Problem with invalid /Pages on root obj...
    To unsubscribe from this thread, please visit the message page at Re: Problem with invalid /Pages on root obj.... In the Actions box on the right, click the Stop Email Notifications link.
    Start a new discussion in PDF Language and Specifications by email or at Adobe Community
    For more information about maintaining your forum email notifications please go to http://forums.adobe.com/message/2936746#2936746.
    Olaf Druemmer | Managing Director | callas software GmbH | Schoenhauser Allee 6/7 | 10119 Berlin
    Tel +49.30.4439031-0 | Fax +49.30.4416402 | o.druemmer@callassoftware.com | www.callassoftware.com
    Amtsgericht Charlottenburg, HRB 59615 | Geschäftsführung: Olaf Drümmer, Ulrich Frotscher
    ►  PDF modulo X:
    ►  Medien-Workflows mit PDF/X-4 praktisch umsetzen
    ►  Workshop mit Robert Zacherl und Olaf Drümmer
    ▷  22.10.2013  Hamburg, Radisson Blu - www.amiando.de/pmx-hamburg
    ▷  20.11.2013  München, Hotel Vitalis - www.amiando.de/pmx-muenchen
    ▷  21.11.2013  Frankfurt, Intercontinental - www.amiando.de/pmx-frankfurt
    Sep 19, 2013 4:21 AM   in reply to WCoder
    Looks right.
