File Complexity/Size Maintenance; Paths vs Compund Objects
Sep 19, 2013 1:19 PM
Tags: #save #path #stroke #filesize
I have found myself using different methods to make designs, but I was wondering what was the best practice for archiving FINISHED products.
In terms of anchor and path complexity: would it be best to save files as paths with width controls, or should I be outlining strokes and flattening as compound objects?
If it turns out that the results would vary with every project, then I can accept saving two versions and deleting whichever happens to be the bigger file.
    Sep 19, 2013 2:41 PM   in reply to Puzmen
    Puzmen,
    FINISHED products
    And you believe in that concept?
    You should always keep a copy of the fully editable version before it(s continued development prospect) is destroyed.
    Sep 20, 2013 7:22 AM   in reply to Puzmen
    Puzmen,
    let's pretend I have a client
    What about a separate PDF for that, either saved without AI editing capabilities or printed to PDF, for smallest possible file size?
    Sep 20, 2013 3:32 PM   in reply to Puzmen
    Puzmen,
    I believe the saving option Smallest File Size is about as good (small) as it gets.
    http://help.adobe.com/en_US/illustrator/cs/using/WS714a382cdf7d304e7e0 7d0100196cbc5f-654fa.html
