K8 L
How can I retain the high resolution of images saved in a PDF?
Sep 20, 2013 6:52 AM
Tags: #image_quality #high_resolution #adobe_xi_pro #save_.pdf
I'm using the trial version of Acrobat XI. The images are 1440dpi but always save ate 120dpi. The PDF is for the content of a picture book so I need to be able to save them at a minimum of 300dpi. Any help would be very much appreciated.
    Sep 20, 2013 8:43 AM   in reply to K8 L
    Something to try -
    In Acrobat's preferences select "Convert to PDF". Select the incoming image format. Use the "Edit" button to play with the configuration options.
    As well, consider giving any Distiller job options in use a look-see. Look over the configuration  for "Images".
    Be well...
    Sep 20, 2013 12:16 PM   in reply to K8 L
    If you are printing to the Adobe PDF printer or using Distiller, select the job settings of either print or press. They will save graphics at a higher resolution. The default for color images in the Standard settings is 150 dpi. Press and Print default at 300 dpi. You can change there settings to a new settings file and increase the resolution if you desire.
    Sep 24, 2013 7:46 AM   in reply to K8 L
    I think I maybe know why Word is making them tiny.
    Suppose you have your a 144 dpi image that is 10 cm high. Now suppose you change the resolution to 1440 dpi. This must reduce the image size to 1 cm high.
    So if you did that and placed in Word, it will show the "correct" size (i.e. 1 cm high). You can always scale images once in Word.
