JerryHaselden
illustrator won't install using adobe creative suite 5.5 design standard?
Sep 20, 2013 1:22 PM
i am installing adobe creative suite 5.5 design standard, all of the softwares will install but it will not install illustrator? PLEASE HELP! Here is the troubleshooting information.
Exit Code: 6
-------------------------------------- Summary --------------------------------------
- 0 fatal error(s), 7 error(s), 5 warning(s)
WARNING: DW024: The payload: Adobe Photoshop CS5.1 Core  {08EF22BC-43B2-4B4E-BA12-52B18F418F38} requires a UI parent with following specification:
                Family: Photoshop
                ProductName: Adobe Photoshop CS5.1 Core_x64
                This parent relationship is not satisfied, because this payload is not present in this session.
ERROR: DW025: The payload with AdobeCode:  {857CC5F0-040E-1016-A173-D55ADD80C260} has required dependency on:
                Family: InDesign
                ProductName: Adobe InDesign CS5.5 Icon Handler x64
                MinVersion: 0.0.0.0
                This dependency is not satisfied, because this payload is x64 and is not supported on this machine.
                Removing this dependency from list. Product may function improperly.
WARNING: DW025: The payload with AdobeCode:  {857CC5F0-040E-1016-A173-D55ADD80C260} has recommended dependency on:
                Family: Adobe Web Suite CS5.5
                ProductName: Adobe Media Encoder CS5.5 X64
                MinVersion: 0.0.0.0
                Removing this payload from the dependency list.
----------- Payload: {AC003BC0-704F-4F02-A72E-AC8B7044DE24} AdobeOutputModule 3.1.0.0 -----------
ERROR: DF024: Unable to preserve original file at "C:\Program Files\Common Files\Adobe\Bridge CS5.1 Extensions\Adobe Output Module\mediagallery\resources\flashgallery\AUTORUN.inf" Error 5 Access is denied.(Seq 83)
ERROR: DW063: Command ARKDeleteFileCommand failed.(Seq 83)
----------- Payload: {CFA46C39-C539-4BE9-9364-495003C714AD} Adobe SwitchBoard 2.0 2.0.0.0 -----------
WARNING: DF029: ARKServiceControl::StartService: Service not started/stopped SwitchBoard. Current State: 0 Exit Code: 0 Service Specific Exit Code: 0(Seq 1)
----------- Payload: {53CF3920-648B-4F99-8D05-6A6C5298F57B} Creative Suite 5.5 Design Standard 5.5.0.0 -----------
WARNING: DW036: Payload cannot be installed due to dependent operation failure
ERROR: DW050: The following payload errors were found during install:
ERROR: DW050:  - Adobe Illustrator CS5.1: Failed due to Language Pack installation failure
ERROR: DW050:  - AdobeOutputModule: Install failed
ERROR: DW050:  - Adobe Illustrator CS5.1_AdobeIllustrator15_1en_USLanguagePack: Install failed
Bookmarked By (1)
