The_CrY
Problem with Level Adjustment Layer in PSE7
Sep 24, 2013 4:09 AM
Tags: #adjustment_layer #levels #photoshop_elements_7 #pse_7
I have a problem with the level adjustment layer in PSE 7.0. I made this picture which shows exactly the way I want in PSD format, but when I save it to JPG all the adjustment layers are lost. I have tried to achieve the same result using simple Enhance >>Adjustments >> Levels, but I can't get the same result with the same settings as with the Adjustment Layer.
How can I solve this?
I saw in some tutorial that it might help to add a new layer above the adjustment layer and then Merge Visible, but that doesn't work either.
I hope someone can help me so I can finish the picture.
  • 99jon
    Jan 6, 2010
    Sep 24, 2013 4:17 AM   in reply to The_CrY
    It should contain all of your levels edits if saving a jpeg from PSD.
    Try opening the PSD and choosing Layer >> Flatten Image and then use File >> Save As and choose jpeg format.
    Close the PSD afterwards but don't re-save it - in order to preserve your layers for future editing, if required.
  • 99jon
    Jan 6, 2010
    Sep 24, 2013 4:38 AM   in reply to The_CrY
    Yes that's how it works. You can't have layers with a saved jpeg, but the effects of the levels adjustment should show up in the jpeg image.
    Sep 24, 2013 4:45 AM   in reply to The_CrY
    Is your question why you lost the layers (not the effect of the layers)?
    When you save as a jpg it flattens the image but the net effect of your adjustment layers should be there. If you want to preserve the layers themselves first save it as a PSD file.
    Sep 24, 2013 5:00 AM   in reply to The_CrY
    Can you reproduce the problem and post a snapshot of your Layers Palette?
    Also, is it possible that the visibility of the adjustment layer was turned off when  you did the save to jpg?
  • 99jon
    Jan 6, 2010
    Sep 24, 2013 9:24 AM   in reply to The_CrY
    It would be helpful to see a screencap of your layers pallet. Are both of your adjustment layers (hue/saturation and levels) clipped to the layers below. If not hold down your alt key and hover on the dividing line between the layers until you see two small circles and then click. If the layers are properly clipped the thumbnails in the layers pallet should move slightly to the right.
  • 99jon
    Jan 6, 2010
    Sep 24, 2013 9:57 AM   in reply to The_CrY
    The levels adjustment may have been accidentially locked. Try unlocking it.
    Sep 24, 2013 2:19 PM   in reply to The_CrY
    Please upload your PSD file to a file-sharing service such as http://www.sendspace.com (it's free) and let us know the URL.
    Sep 24, 2013 9:09 PM   in reply to The_CrY
    It looks like the problem is your image size is rather large in comparision to your available screen size and your doing your adjustments at roughly 18% view.
    Photoshop elements uses interpolation to show the images on screen, so you really don't see the true results unless you view an image at 100% view (actual pixels)
    If you try doing the steps from the beginning with your image at 100% view, does that make a difference?
    (Double click on the Zoom Tool in the toolbox for 100% view (actual pixels))
    Sep 25, 2013 4:10 PM   in reply to The_CrY
    Good one, R_Kelly !
