Printing an exported PDF file from InDesign
Sep 24, 2013 6:27 PM
I have exported a few documents form InDesign to PDF. When I print the documents, some parts get cut off (top section or bottom section) but there is still room on the paper. I'ts like the printer decides not to print those sections. I am printing on 5x7inch paper and all my documents show their sizes as 5x7inches.
    Sep 24, 2013 8:43 PM   in reply to J. Cris
    I think it's a printer settings problem...
    Have you check the borderless setting of your printer?
    Probably to print without margins you have to set some parameters on the printer driver dialog box...
    I hope this help
    Sep 25, 2013 2:10 AM   in reply to J. Cris
    This is a general issue with PDFs. If you don't consider the non-printable margin of a printer when setting up your document, this can happen. Usually, when viewing the PDF in a read and printing from there, there is an option like "Fit document to paper" which reduces it to the the printable area. If your printer can print borderless, you don't need that.
    Sep 25, 2013 6:27 AM   in reply to J. Cris
    But are you sure that your printer can print borderless?
    Can you print borderless by Indesign?
    Can you print borderless by other Applications?
    Sep 25, 2013 6:38 AM   in reply to J. Cris
    Well, but if you can print borderless from Indesign what are the settings that you cannot adjust in Acrobat Reader (or acrobat Pro)?
    Sep 25, 2013 7:07 AM   in reply to J. Cris
    Maybe It could be depend on PDF export setting used in Indesign...
    Anyway, try this steps:
    Open the PDF in Acrobat Pro
    Go to the "Tools" menu and select the "Pages" tab.
    Then select the option for "Crop Pages."
    Double click into the document view and set all the margins to 0.
    Save and retry to print
    Sep 25, 2013 8:02 AM   in reply to J. Cris
    Stop trying to choose the paper by document size, click page setup, go into the printer driver an d pick 5 x 7 borderless as the page size, and see if that works.
    Have you try to click on Page Setup and set the paper size to 5x7 borderless (if this option exists) and not only 5x7 ?
    Sep 25, 2013 8:04 AM   in reply to Francesco Della Peruta
    Oh Peter, same idea in the same time!
    Sep 25, 2013 8:34 AM   in reply to J. Cris
    Sep 25, 2013 8:35 AM   in reply to Peter Spier
    And it wouldn't surprise me if the non-printing borders are asymmetrical.
    Sep 25, 2013 8:37 AM   in reply to J. Cris
    Not a problem, you are welcome.
